HI FI Speaker repainting
21 Oct 2006
Bedfordshire
I've managed to get a pair of secondhand fairly high end Mission 775 Hi Fi speakers.
Quite rare beasts these, and I had to get them even though they are the wrong colour finish for me......
Whats the best way to make rosewood finish black? Its not veneer, just that thin wood look alike plasticy type covering.
I'm considering masking up, a very light sand/clean, and applying a thin coat of black satin emulsion with a small roller.
As long as it sticks should be fine, as they won't be handled much.
No too durable I know, but does anyone have a better suggestion for type of paint?
Cheers,
John
If it's a plastic foil wrap, sanding will go through it to the MDF beneath, and emulsion will not stick. I'd go for a single coat on non-drip gloss (not water based).
Or I suppose youi could go to Halfords for aerosol satin black spray.
Maybe just a good clean with white spirit then emulsion maybe?
I thought about Halfords spray myself. Guess it might be a better option as I'm masking them up anyway.
Just thought a small roller would be less messy, and avoid overspray problems
Thanx for the Halfords spray suggestion...
After a quick test to ensure they were working, they were firstly wiped off with white spirit to remove any polish.
Took 3 hours to mask up properly, then a light rubbing down with scotchbrite to key the surface.
Then another clean with white spirit to remove all traces of dust.
Applied 3 coats of Halfords Satin Black spray, used 2 cans of 500ml. Think they were 6 quid a can.
Allowed 15 mins between coats, then left for half an hour before carefully removing masking tape. Its best to do this before paint is fully hard so edges peel easier.
Result is superb, they are VERY close in appearance to my other Mission speakers, the woodgrain effect is still there, and paint has adhered very well.
