DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
Roof tiles make a knocking noise
This topic originated from the How to page called Tiled Roof
Click here to return to the page called Tiled Roof.
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering
Search this topic :: View previous topic :: View next topic
Author Message
BenLovesDIY
from United Kingdom
PostPosted: Thu Jan 04, 2007 2:03 pm Reply with quote
OK this is my first post, im sure there will be many to follow!
I live in a converted bungalow. Upstairs has flat roofs. However, when the wind blows the tiles on the sides of the rooms make a knocking sound.
Any idea why this is happening??
Ben
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 98 times
PostPosted: Thu Jan 04, 2007 2:09 pm Reply with quote
Need more info on type of roof, I'm guessing a gable end which have a undercleat which support the cement & the overhung of the tiles, missing cement maybe?
A photo will help us
Back to top
 Alert Moderators
BenLovesDIY
from United Kingdom
PostPosted: Thu Jan 04, 2007 2:14 pm Reply with quote
Thanks for the quick reply... I will take a picture and post it on here tomorrow!
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1111 times
PostPosted: Thu Jan 04, 2007 10:33 pm Reply with quote
Do you mean vertical tiles on the sides of the dormer?
If so they are not fixed properly
Back to top
 Alert Moderators
BenLovesDIY
from United Kingdom
PostPosted: Fri Jan 05, 2007 9:17 am Reply with quote
Hi, Yes I mean the virtical sides of the doormer. How would I fix them down properly? Is it as simple as some cement under them?
Back to top
 Alert Moderators
^woody^
from United Kingdom
Thanked: 1111 times
PostPosted: Fri Jan 05, 2007 1:55 pm Reply with quote
No, vertical tiles are not fixed with cement (or mortar!)
They should be nailed, and properly spaced so that the weight of the row above and the pressure of the tiles each side hole them all as one.
You need to look to see if they are all close togther and the vertical spacing is not too much. You should not be able to lift one up easily.
If it is a big problem with spacing then they will all require respacing and refixing. If it is just a few isolated, then try exterior grade Gripfill
Back to top
 Alert Moderators
markie
from United Kingdom
PostPosted: Sat Jan 06, 2007 12:00 am Reply with quote
Are you sure it's the tiles which are making the noise. ? is there nothing left on the flat roof icon_idea.gif
If the tiles are hung the way they should be and everyone nailed they shouldn't move unless it's a gale force wind icon_smile.gif
Back to top
 Alert Moderators
richardgjones
from United Kingdom
PostPosted: Mon Dec 03, 2007 8:44 pm Reply with quote
Our house does the same thing too. A very annoying tile tap/knocking sound whenever there's a reasonable amount of wind.
I checked the obvious things like a loose tile, flashing etc (but the house is only 18mths old).
Eventually when up in the lost I realised it was wind pressure within the loft space doing it. You could see the air pressure pressing on the tile lining and the tiles themselves being slightly lifted causing the knocking sound.
So having found the problem, any idea on how to prevent it?
Should I get the tiles siliconed together (or at least in the area above the main bedroom).
Is it a design problem with the house (too much, too little eve venting)?
Any suggestions appreciated as it's getting like water torture waiting for the clicks and knocks
Back to top
 Alert Moderators
Mw Roofline
from United Kingdom
Thanked: 161 times
PostPosted: Tue Dec 04, 2007 11:41 am Reply with quote
Its because building inspectors are so anal when it comes to ventilation with new houses. Not only do you have to have breathable felt, copious amounts of channel venting along the soffit/above the fascia but also roof tile vents. My mates new build loft is like a wind tunnel icon_eek.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Roofing and Guttering All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
Mysterious knocking noise from roof...except when tv is on! 2 200 Tue Aug 14, 2012 11:07 am
Foam on the underside of roofing tiles to make them watertig 9 180 Wed Apr 10, 2013 8:38 pm
Adding insulation to cold roof to make warm roof 13 1380 Wed Mar 23, 2011 9:50 pm
how to make a flat roof into a slight ptch roof 7 5200 Fri Aug 05, 2005 9:13 pm
5" Guttering, do they still make it ?? 2 80 Wed Jun 20, 2012 8:27 am
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy.
