I would like to gain a better understanding of my heating system.
Any help with the following questions from anyone would be great.
I have a Vaillant ECOmax Combi-Boiler (Combi Compact VUW GB 236E).
Question 1
I have 9 radiators installed. 4 downstairs and 5 upstairs.
In what order what do I bleed them?
I was told that I need to know the position of them with respect to the boiler to do this.
How do I determine the positon and hence bleed order?
Question 2
Should the radiators be bled when the system is hot or cold?
What would be the advantages /disadvantage?
Question 3
Recently I had the problem where the pressure increased over a period of time.
I found this to be the filler hose valve which had been left connected and had not been turned off correctly so was still trickle passing water. I have since disconnected it…………….
…….Having been emptying / topping up with water....I think I need to put an inhibitor into the system.....what does it do / how does it work?
Can I put the inhibitor into the system through any radiator?
Question 4
When adding the inhibitor, do I need to completely empty the system through the drain point first?
Or is there a way to do it without draining?
Question 5
What would be the correct method to use to balance my system once I have it filled and at the correct pressure?
Question 6
Is there is there anything else you think I should consider?
Has anyone any web links to pass on, which describe central heating systems in a clear manner to beginners of the subject (or good books / DVD’s to recommend)?
All advice would be very much appreciated.
Question 1
Question 2
Question 3
Question 4
Question 5
Question 6
