DIYnot
Local | Network
   DIYnot > Forums
Local | Network
DIYnot Network Local DIYnot Network Local
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     About CookiesCookies     SearchSearch     LoginLogin
what is the difference between 1 gang and 2 gang please
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics UK
Search this topic :: View previous topic :: View next topic
Author Message
judy2611
from United Kingdom
PostPosted: Thu Feb 15, 2007 11:55 am Reply with quote
Hello,
On a light switch can you tell me the difference between 1 gang and 2 gang.
Thanks.
Back to top
 Alert Moderators
If you do not want to see this advert, click here to login or if you are new click here to join free.
FredFlintstone
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 15, 2007 12:03 pm Reply with quote
judy2611 wrote:
Hello,
Thanks.
Hi Judy,
One gang has one switch. Two gang has two switches. Guess how many switches a three gang has?
Fred
Back to top
 Alert Moderators
judy2611
from United Kingdom
PostPosted: Thu Feb 15, 2007 12:05 pm Reply with quote
Thanks Fred for your answer, but in B and Q . they had one switch with one gang and 2 gang, then a double switch with 1 gang and 2 gang , so any ideas please ? I wont reply to the 3 gang one .........icon_biggrin.gif
Back to top
 Alert Moderators
FredFlintstone
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 15, 2007 12:11 pm Reply with quote
Hmmmm, must be one way and two way.
One way is that it's the only switch to control a light, two way is a switch that controls a light where there is another switch that also controls the light, such as at the top and bottom of the stairs.
I hope I've got it the right way round!
Back to top
 Alert Moderators
judy2611
from United Kingdom
PostPosted: Thu Feb 15, 2007 12:23 pm Reply with quote
Thanks Fred for your help. It does make sense what you said , but I am still confused a bit .........but thanks anyway .......icon_biggrin.gif
Back to top
 Alert Moderators
IJWS15
from United Kingdom
Thanked: 40 times
PostPosted: Thu Feb 15, 2007 1:44 pm Reply with quote
The moral is that B&Q frequently get it wrong!
As Fred said one gang is one switch, two gang is two switches . . .
One way switch has two terminals on the back for each switch, two way has three terminals for each switch, intermediate has four connections per switch.
Double pole switches have more connections and are a different story (usually uses on righ circuits rather than light circuits)
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 446 times
PostPosted: Thu Feb 15, 2007 3:06 pm Reply with quote
Back to top
 Alert Moderators
judy2611
from United Kingdom
PostPosted: Thu Feb 15, 2007 11:29 pm Reply with quote
Thank you all , I am really really confused now , but thanks. icon_biggrin.gif
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1432 times
PostPosted: Thu Feb 15, 2007 11:39 pm Reply with quote
Does this help?
Single-gang socket
Two-gang socket
One-gang light switch
Two-gang light switch
Three-gang switch
One gang dimmer
Two-gang dimmer
Three-gang dimmer
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 1 time
1 gang:
2 gang:
Do the pictures make it easier?
A 1 way switch can turn a light on or off from a single point and has 2 terminals on the back (common and L1)
A pair of 2 way switches can turn a light on or off from two points. Each switch has 3 terminals (common, L1 and L2)
A 1 gang 1 way switch looks the same from the front as a 1 gang 2 way switch etc.
Don't rely on B&Q for electrical advise, infact don't rely on them for advice. icon_smile.gif
Davy
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 1 time
PostPosted: Thu Feb 15, 2007 11:40 pm Reply with quote
ARGHHH!!!!!!
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1432 times
PostPosted: Thu Feb 15, 2007 11:42 pm Reply with quote
Hahahahahahahahahahaha
4-gang dimmer
3-gang socket
4-gang socket
Faceplates with larger numbers of switches are usually assembled on-site by the electrician using a Gridswitch system (you may have seen these in shops and office)
Back to top
 Alert Moderators
ELZ4742
from United Kingdom
Thanked: 16 times
PostPosted: Fri Feb 16, 2007 12:05 am Reply with quote
gang-ster
ging-gang-gooly
gang-rene
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 446 times
PostPosted: Fri Feb 16, 2007 8:13 am Reply with quote
That Stilton & Broccoli soup I just had was YUMMY!
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics UK All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics   Replies   Views   Posted
2 gang switch to a dimmer with a difference 3 660 Mon Aug 20, 2007 4:37 pm
Difference between old two-way switch and new two-way switch 4 200 Fri Apr 22, 2011 2:40 am
What's the difference? 5 140 Fri Jan 20, 2012 10:38 pm
Difference between Single and Double pole MCB 2 2600 Tue Mar 27, 2012 1:49 pm
Difference between a fuse board, fuse-box and CU? 4 220 Tue Feb 08, 2011 3:06 pm
DIYnot
Find an Expert | Find a Supplier | Search DIYnot.com
Network | Advertising | Newsletter
DIY | DIY How To | @home | DIY Wiki | DIY Forum
By using this site you agree to our Terms of Service / Disclaimer.
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
