| Author |
Message |
mlb3c
Joined: 29 Jan 2006 Posts: 1935 Location: Georgia, United States of America
Posted: Sun Jan 29, 2006 10:34 pm |
the posts are v shape metal posts that are speared near the bottom and approximately 5 feet long-any ideas on how to remove them? There are 15 of them.
Wow! what a great idea! I wonder why I didn't think of that. NOT. I failed to mention that it is believed (judging by one that was not installed) that is is "sunk" in the ground (very hard red clay ground) approximately 2 ft. Some very determined person who apparently found a great deal on the "posts" or whatever you call them and put cheap fencing with them--that was the easy part to take down.
| Back to top |
If you do not want to see this advert, click here to login or if you are new click here to join free. |
breezer
Joined: 03 Jan 2003 Posts: 23330 Location: Sussex, United Kingdom Thanked: 24 times
Posted: Sun Jan 29, 2006 10:41 pm |
pull very hard or dig them out |
| Back to top |
Nestor_Kelebay
Joined: 19 Jan 2006 Posts: 494 Location: Canada Thanked: 6 times
Posted: Mon Jan 30, 2006 4:28 am |
Here's what I did to remove some 4X4 wooden fence posts that were stuck in the ground from an old old fence along the perimeter of my parking lot:
1. I coiled a chain around the fence post (about 5 or 6 turns) and connected both ends of the chain together so that when I pulled upward on the slack where the ends were connected, the chain tightened up around the post.
2. I hooked the slack onto the top of a 2X4 and leaned that 2X4 against the post I was wanting to pull out.
3. Then I lifted the bottom of that 2X4 with a scizzor type car jack.
This would work better if you could get one of those old jacks that was meant to lift a car by it's bumper and hook the chain on that.
Alternatively, could you grab tightly onto the V shaped steel posts with a pair of Vice Grip pliers and use a piece of 2X4 as a fulcrum to pry the posts out by using a long pry bar to pry upward on the jaws of the Vice Grips? |
| Back to top |
Hitachimad
Joined: 06 May 2005 Posts: 611 Location: Somerset, United Kingdom Thanked: 11 times
| Back to top |
Nige F
Joined: 28 Jun 2005 Posts: 15566 Location: United Kingdom Thanked: 726 times
| Back to top |
mlb3c
Posted: Fri Feb 03, 2006 11:31 pm |
I think I'll put up birdhouses instead....the posts are never coming out. |
| Back to top |
Goomer
Joined: 25 Mar 2006 Posts: 1 Location: United States of America
Posted: Sat Mar 25, 2006 2:30 am |
| Back to top |
Drakkhen
Joined: 25 Mar 2006 Posts: 8 Location: Hertfordshire, United Kingdom
Posted: Sat Mar 25, 2006 10:07 am |
Don't complain, in France they put cement around the post...
In France they simply cut them because to remove them is very very tough. |
| Back to top |
Thermo
Joined: 21 Oct 2004 Posts: 9982 Location: Sussex, United Kingdom Thanked: 148 times
Posted: Sat Mar 25, 2006 10:48 am |
two options, dig down to expose the top of the concrete and cut them off there and then back fill, or dig around the concrete and use a sledge hammer to loosen them then use the posts own leverage to get them out. Thats all i do when removing fence posts |
| Back to top |
chamac
Joined: 27 Mar 2006 Posts: 2 Location: United Kingdom
Posted: Mon Mar 27, 2006 9:38 pm |
drill a hole into the concrete and then hammer a chisel into the drilled hole
this should split the concrete |
| Back to top |
chamac
| Back to top |
fiveminutejob
Joined: 16 Jul 2006 Posts: 53 Location: United Kingdom
Posted: Sat May 05, 2007 2:06 am |
Having struggled for ages trying to lever out the first of eight old wooden post & spikes firmly set in earth, not concreted, I simply poured some WATER down the sides of each spike (I'd already wiggled them around to create a bit of room). This provided sufficient lubrication to help each one slide out fairly easily with sufficient leverage. Saved a lot of back pain!
Hope this helps. Worked for me. |
| Back to top |
