I am wanting to build a detached garage into a sloping garden but find that my planned base level would be 6 inches above a 4 inch field drain pipe which I found runs across my garden. What can I do?
Thicken the slab to form a beam which goes down the drain invert level, or put some mesh in the slab to (hopefully) spread the load tot he adjacent ground.
