hendan
Joined: 29 Oct 2002 Posts: 1 Location: United Kingdom Thanked: 0 times
Posted: Tue Oct 29, 2002 9:52 am Post Subject: concrete blocking a U trap |
concrete is blocking a 3 inch cast iron U trap that got in when a contractor rinsed his tools after doing a concrete job!! The U trap only has one clean out plug.
Any advice to correct this problem is much appreciated.
Drew
Joined: 28 Oct 2002 Posts: 19 Location: United Kingdom Thanked: 0 times
Posted: Tue Oct 29, 2002 6:33 pm Post Subject: Re: concrete blocking a U trap |
There is a product called sealoclean (different companies may use different brand names), that is a brick acid used to clean morter splashes of stone work. This might be worth a try, and should be mild enough not to affect the cast iron. |
