DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
vokera 20/80 flowmatic no heating and hotwater
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
stew40
from United Kingdom
Thanked: 0 times
PostPosted: Sun Aug 26, 2007 10:29 pm    Post Subject:
Reply with quote Thanks
I have a vokera 20/80 flomatic combi with no hot water or heating the pilot light is on but the main burner fails to ignite this has only happened after coming back from one weeks holiday,i have replaced pressure vessel about three weeks ago,any help will be welcome. icon_confused.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Sun Aug 26, 2007 10:32 pm    Post Subject:
There are several things but it all depends on what the boiler does do!
Pump, gas valve, pcb etc.
Perhaps you need a conpetent boiler engineer to diagnose the fault?
Tony
Pressure vessel??? Maybe the expansion vessel?
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 12:30 am    Post Subject:
Your Spidey sense are struggling with this detail as well then Tony?
__________________
Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man
Back to top
 Alert Moderators
stew40
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 7:58 am    Post Subject:
Re: vokera 20/80 flowmatic no heating and hotwater
[quote="stew40"]I have a vokera 20/80 flomatic combi with no hot water or heating the pilot light is on but the main burner fails to ignite this has only happened after coming back from one weeks holiday,i have replaced pressure vessel about three weeks ago,any help will be welcome. icon_confused.gif The pump and fan is running the pin on the dhw micro switch is moving when tap is turned on but the pin on the boiler flow switch is stuck in and does'nt move at all,could this be the problem icon_question.gif
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 9:42 am    Post Subject:
The fan runs at high speed yes?
If so then when was the boiler last serviced?
Would suggest APS problem or clogged venturi. Both jobs for a CORGI.
__________________
Regards
Dan Robinson
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Mon Aug 27, 2007 11:06 am    Post Subject:
You have missed what he has concealed in his last post dan!
To the OP. I dont understand how you can ever expect the system flow to not be operating and for the boiler to still fire up!
Its a safety device to PREVENT firing without a flow of water.
How can you say the pump is running? Is the shaft turning? Is there water in it? Is the impeller full of dirt? Is it full of air?
The problem is almost certainly associated with the pump but in theory the flow switch could be faulty or stuck but thats HIGHLY unlikely so dont touch it.
Tony
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 27, 2007 11:09 am    Post Subject:
icon_redface.gif Missed that last line. Hangover starting to hurt and I rrrreeeeaaallllyyyy can't be ar7sed to do my estimates.
Punctuation goes a long way to making problems easier to solve. When you get reams of text like that it makes reading it so much more tedious; one gives up after a while.
__________________
Regards
Dan Robinson
Back to top
 Alert Moderators
scatmanjohn
from Colombia
Thanked: 4 times
PostPosted: Mon Aug 27, 2007 12:26 pm    Post Subject:
Are you sure about that Tony.
Remember the flow switch moves in with water flow.
That means that this one is stuck in a dangerous condition.
I visited a vokera mynute last week that ran dry and set on fire icon_eek.gif
The question is, is the fan going from slow to fast speed, and if it is, it is likely to be the usual fault caused by lack of servicing.
Just out of interest, when was it last serviced properly
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 18 times
PostPosted: Mon Aug 27, 2007 12:32 pm    Post Subject:
I would say it is highly likely that the boiler has been neglected. Nothing a good service will not cure.
Have yet to replace an expansion vessel on this model.
Back to top
 Alert Moderators
rkid45689
from United States Minor Outlying Islands
Thanked: 0 times
PostPosted: Sun Sep 21, 2008 2:54 am    Post Subject:
my boiler isnt heating up water.. what do i have to check to get it fixed?
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Sun Sep 21, 2008 10:31 am    Post Subject:
start a new thread and include some details.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Hotwater only when heating is on...and not very hot!! 2 400 Sat Jan 07, 2006 1:01 pm
Profile 60E Boiler, Hotwater but no Central Heating?? 5 240 Mon Sep 15, 2008 9:04 pm
No hotwater or heating - Gas central heating 10 700 Sat Dec 22, 2007 7:53 pm
Heating but no hotwater, and yes I have searched the forum! 18 1160 Tue Sep 11, 2007 1:56 pm
Santon Premier tp150b not heating water on the hotwater only 3 260 Mon Jul 06, 2009 7:11 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
