DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Replacing Intermediate switches
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
  View previous topic :: View next topic
Author Message
fullers
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 28, 2007 8:19 pm    Post Subject:
Reply with quote Thanks
Hello...I have recently changed all of our old light switches in the house and since doing so have not been able to use kitchen lights at all (there is no current reaching the switch), and the bathroom light (directly above) will only come on if the light in the bedroom next door is on.
On checking the old switches I can see that out of the three switches upstairs, two were intermediate switches and wired L1 and L3only - surely these are the same as simple two way switches wired as one way ones? The problem is that I have no idea which switches used to be the intermediate ones! Any help (and light in our kitchen) would be gratefully received
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Aug 28, 2007 8:35 pm    Post Subject:
No, intermediate switches are not the same as anything else.
you can only have two 2-way switches in a lighting circuit, any additional ones have to be intermediate.
See how many wires you have behind each switch. a 2-way switch takes 3 wires, an intermediate switch takes four.
From what you describe, I amnot sure that they are really Intermedaite switches.
Please describe how many switches you have, and what they do.
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Tue Aug 28, 2007 8:38 pm    Post Subject:
The OP says they were wired across L1 and L3 only, so it sounds like they were being used as a 1 way switch.
I have done this occasionally when I've run out of 1G 2W switches, but had an intermediate on the van.
Have you checked all the switches for a loose / broken connection?
__________________
I downlights
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Aug 28, 2007 8:39 pm    Post Subject:
You will probably find it easiest to start by fixing the light nearest to your Consumer Unit, and working along from there. Did you change any of the ceiling fittings? this is a much more common cause of lighting circuits not working right.
Back to top
 Alert Moderators
fullers
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 28, 2007 8:54 pm    Post Subject:
All of the lights downstairs work fine, except the kitchen one. The only switch I changed downstairs was a 2 way switch (wired as a 1 way) which I replaced with a dimmer.
Upstairs I replaced 3 light switches - 2 appear to have been the intermediate ones as described above but wired as a 1 way switch - all of the lights work but the bathroom one doesnt - which wasnt replaced at all.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Aug 28, 2007 8:57 pm    Post Subject:
Back to top
 Alert Moderators
fullers
from United Kingdom
Thanked: 0 times
PostPosted: Tue Aug 28, 2007 9:04 pm    Post Subject:
JohnD wrote:
Sorry - no didn't change any light sockets - only the wall switches
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 20 times
PostPosted: Wed Aug 29, 2007 6:50 am    Post Subject:
If the lighting wiring is looped at the switches, then transposing one leg the live loop would mean the switch would then control it's own light, plus everything else 'downstream'
__________________
If it isn't broken, keep fixing it until it is
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Mixed type switches - intermediate switches 12 1000 Sat Sep 03, 2005 7:35 pm
Intermediate Switches 2 400 Thu Jan 26, 2006 10:33 am
Intermediate switches 6 1120 Sat Feb 03, 2007 1:57 pm
Replacing an intermediate switch not in 3 way switching 6 860 Fri Dec 26, 2003 12:57 pm
3 way light switching without an intermediate switch ?? 7 1280 Sun Sep 23, 2007 12:09 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
