Wilbur111
Joined: 28 Aug 2007 Posts: 11 Location: Edinburgh, United Kingdom Thanked: 0 times
Posted: Tue Aug 28, 2007 11:48 pm Post Subject: Replacing a toilet with a shower |
I have a room with a toilet in it. I'd rather have it as a shower room.
What should I do about the soil pipes once I've removed the toilet bowls? How do I block them off?
Or can I simply have the drainage water going down the toilet's waste pipe instead of plumbing it into the sink's drain?
Thanks a lot. |
jonny2
Joined: 28 Aug 2007 Posts: 7 Location: Essex, United Kingdom Thanked: 0 times
Posted: Wed Aug 29, 2007 12:14 am Post Subject: |
Its fine to use the soil pipe as waste outlet for the shower, by just cutting back if necessary, capping the end, then boss into the top with your 42mm shower waste. A lot depends on where your soil pipe runs, i.e above or below floor level etc. but if you are installing shower enclosure directly where toilet used to be and you can get a reasonable 'fall' into the soil pipe all will be ok.
If it ain't broke, fix it till it is. |
Wilbur111
Posted: Wed Aug 29, 2007 12:59 am Post Subject: |
Excellent news. Thanks very much.
What I want is to have a wet room and I'm happy to raise the floor level if needs be. The pipe runs below the floor so I think it should all work just fine.
Thanks again. It's appreciated - particularly at this hour. |
Dan_Robinson
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Wed Aug 29, 2007 6:45 am Post Subject: |
Remember wet rooms are heavy - make sure the floor its strong. __________________ Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man |
TicklyT
Joined: 30 Jul 2006 Posts: 1873 Location: Hampshire, United Kingdom Thanked: 20 times
Posted: Wed Aug 29, 2007 7:05 am Post Subject: |
If the toilet waste is in the right position you can get traps for wetroom floors that fit straight into the end of a vertical 4" pipe trimmed to floor level or a fraction below. __________________ If it isn't broken, keep fixing it until it is |
