DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Downlights install
This topic originated from the How to page called Types of lighting
Click here to return to the page called Types of lighting.
  View previous topic :: View next topic
Author Message
pl_donnelly
from Ireland
Thanked: 0 times
PostPosted: Thu Aug 30, 2007 11:46 am    Post Subject:
Downlights install
Reply with quote Thanks
First time on site and find it very helpful. Apologies if a bit long but want to give as much detail as possiple.
I have fit down lights in multiple rooms at this stage and have a few question marks?
1) INSULATION: I have chosen to cut away the insulation in the attic space above the down lighter as I figured there would be excess heat to the area, is this overkill and is there a more efficient safety method. I read in one forum entry that terracotta pots where used, seems strange to me. Wonder what the average elec does?
2) JUNCTION BOX: My house uses the loop method of wiring.
In connecting the (on average) 3 down lights I had to discard the old ceiling rose and the connector blocks contained within(switched live, appliance, neutral, earth) and use my own connector blocks with insulation tape (not like doing) to mimic the same but include my down lights live appliance live block.
I have read 20 amp junction box is the better way to go but they seems to only allow a max of 3 wires (1.5mm) and with my 3 down light and source live it make four wires, had to revert to old connector blocks as I could fit 4 wires into junction box terminal, any ideas?
3) 6 DOWNLIGHTS ONE CIRCUIT: I plan on putting 6 50w down lights in my sitting room in lieu on the single 100w appliance. I would imagine 6 x 50w would be a bit much for single feed from loop, wondering if I divide into 2 elements in loop 3 on each and sent the 2 switched lives to same light switch, would this work at sharing load? Not sure if it makes difference as all light on loop system pull off the one line anyway?
Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Display posts from previous:
Page 1 of 1
Jump to:
How do I install downlights? 4 5320 Mon Feb 28, 2005 3:34 pm
Fan on Timer Install with Downlights 11 1100 Sun Jul 20, 2008 8:22 pm
Fire Alarm Install Manuals or guidelines etc 2 260 Sat Sep 23, 2006 10:54 am
how to install a light in attic 3 400 Sun Nov 26, 2006 12:32 pm
Install outside wall light 5 1700 Sat Jan 27, 2007 2:49 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
