DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
zannusi washer dryer 1397w keeps leaking water
This topic originated from the How to page called Washing machine troubleshooting
Click here to return to the page called Washing machine troubleshooting.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
chazza
from United Kingdom
Thanked: 0 times
PostPosted: Fri Aug 31, 2007 9:46 am    Post Subject:
Reply with quote Thanks
Everytime i run my washing my machine keeps leaking water, i have had an engineer out and he couldnt find the problem. The water seems to be comming from the front somewhere but i cant see where. I have checked the pipes at the back and they were still dry and tight. I am lost where to look next. I did think it was the door seal but the engineer said that it was fine, but i am not so sure. Is there anywhere else the water could be comming from. It seems to only leak on the spin cycle.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
sheer1delight
from United Kingdom
Thanked: 1 time
PostPosted: Fri Aug 31, 2007 12:29 pm    Post Subject:
Have you looked at pipe from bottom of drum to the pump and onwards to the drain outlet.?
Back to top
 Alert Moderators
lozza32
from United Kingdom
Thanked: 0 times
PostPosted: Wed Nov 21, 2007 6:46 pm    Post Subject:
washing machine zanussi wjs 1397 w
Did you locate the leak? My machine, same one has started leaking but cannot work out where from. My tennant found water behind the machine but we put it on last night and then onto drain and could not see any signs of water. I did not try the spin cycle so maybe it is that. Perhaps I need a new machine? Do people deliver and take the old one away?
thanks for your help
Back to top
 Alert Moderators
Jakes
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 02, 2007 5:40 pm    Post Subject:
Re: zannusi washer dryer 1397w keeps leaking water
Hi, before you do anything anyone suggest please do this. Start simple. Clean the soap draw, especially the conditioner section. If this blocks water can overflow the compartment during the rinse. It will track down the front of the machine, round the door and down on to the floor. Very hard to see. Most people go over the top and start stripping machines down. When I worked for Service Force ( the repairers for the Zanussi under guarantee) I saw so many engineers and customers miss this.
Back to top
 Alert Moderators
Gibley
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 28, 2008 6:32 pm    Post Subject:
[/quote]Jakes I am having a similar problem although I have a Zanussi FLE116W. I removed the filter to clean it and now when I start my machine I have water coming from the middle of the drain filter front. I have checked that it is screwed back in properly but it still leaks. I don't know what to do and wonder whether the water from the washer dryer could be coming from the same place
Quote:
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Zannusi washer dryer controls stick 3 480 Tue Feb 15, 2005 2:31 pm
ZANUSSI JETSYSTEM EXCEL 1250 FJS 1397W - - LEAKING 5 480 Sun May 25, 2008 2:36 pm
Zanussi Jetsystem 1250 Washing Machine (FJS 1397W) - Water j 2 2500 Fri Nov 11, 2005 3:44 pm
Zanussi WJS 1397W washing machine 3 720 Sun Nov 26, 2006 7:15 pm
Zanusi WJS 1397W Filling When Drying 2 400 Fri Mar 02, 2007 11:09 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
