DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
New bathroom = banging pipes!
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
BrianSE23
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 01, 2007 9:19 am    Post Subject:
Reply with quote Thanks
I have recently had a new bathroom installed, this includes a shower with a mixer. Since the installation, water pipes bang every time any water system in the flat is used - kitchen taps, bathroom taps, toilet, washing machine. Also, when using the shower and you try to increase the temperature, the pipes in the wall vibrate and the water flow stutters. I have a combi boiler. This did not happen before the new bathroom was installed.
Does anybody have experience of this or know what we should be doing (apart from calling a plumber out!) to try and resolve it?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
giblets
from United Kingdom
Thanked: 5 times
PostPosted: Sat Sep 01, 2007 10:45 am    Post Subject:
Sounds to me as though poor installation of the pipework is the cause of the problem. Perhaps a pipe has come out of it's clip (if fitted) and is banging against something else.
If you had the bathroom installed by a professional, get him back to sort it.
Back to top
 Alert Moderators
keego
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 01, 2007 11:46 am    Post Subject:
Check your stop tap to see if it's fully open.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Sat Sep 01, 2007 3:01 pm    Post Subject:
Bet it`s the shower mixer...is it like a horizontal bar on the wall. icon_question.gif LOT of cheapo ones like that about icon_cry.gif should be specificaly for a combi system
Back to top
 Alert Moderators
bengasman
from United Kingdom
Thanked: 188 times
PostPosted: Tue Oct 23, 2007 7:39 am    Post Subject:
Sounds like a typical London builders job (I live in the next postcode), where they did not even bother to clip the pipes. I come across cases like this one a lot. One builder taking on a project and finds the cheapest plumber (smate), apprentice chippie and trainee electrician to do the work. You got 3 options. One, live with it. 2 get a proper plumber to correct all the defects. 3 get the builder back to repair the faults. My guess is that you do not have any test reports, commissioning sheets, or building control approval documents either. It depends on what is done exactly, but any half decent installer should have given you at least a certificate confirming that the electrical work is done by a qualified engineer and tested up to spec.
__________________
Don't feed the troll.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Banging / vibration from new bathroom hot tap 4 80 Wed Mar 04, 2009 4:21 pm
Banging in pipes when toilet is flushed 2 600 Thu Jan 26, 2006 8:22 pm
Gurgling/ Banging/ Whooshing noises from pipes. 9 1180 Mon Feb 06, 2006 9:33 pm
Pipes banging 2 460 Sat Feb 25, 2006 10:15 pm
Boiler pipes banging. 4 560 Wed Jan 11, 2006 1:55 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
