georgefreeways
Joined: 01 Sep 2007 Posts: 1 Location: Bristol, United Kingdom Thanked: 0 times
Posted: Sat Sep 01, 2007 10:03 am Post Subject: swappin my electric shower... |
hello,
just moved to a new house, current elec shower is a piddly 7.5kw rated gainsbourogh. doesn't very well and is cracked etc. so want to swap it with a 9 or 9.8kw Mira Sport Elec thermostatic, the mains pressure is good, so...
there is a 45A isolation switch in the bathroom thats fine, with very beefy cables coming into it (10mm i think).
Supply cables going into shower are equally thick (marked 3138?) and my CU is marked max 60A, but fuses are wire type not switch. Can i put in the Mira without issue? and also can i simply switch all my wire fuse blocks for plug in switches? or is it just as economical to get a new CU fitted?
cheers! |
luminaire
Joined: 11 Jan 2007 Posts: 700 Location: United Kingdom Thanked: 0 times
Posted: Sat Sep 01, 2007 10:09 am Post Subject: |
You really need to upgrade your CU with a split-load type.
One of the best is Starbreaker by Crabtree |
Taylortwocities
Joined: 27 Jul 2006 Posts: 4931 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Sat Sep 01, 2007 10:43 am Post Subject: |
The rewireable fuseboxes are limited to 30A per fuse way and (usually) a max load of 60A.
Either u need a new fuseboard (per above) or one of these. clicky
In any event you really should have RCD protection on the shower circuit. __________________ TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R. |
