MINSKY
Joined: 02 Sep 2007 Posts: 2 Location: Sheffield, United Kingdom Thanked: 0 times
Posted: Sun Sep 02, 2007 8:11 pm Post Subject: long washing machine watse pipe |
Hi We recently had our garage converted to a kitchen and utilty room.Now the sink with the waste is in the kitchen whereas the washing machine is 15 feet away in the utility.I plan to run a waste pipe behind the kitchen units the full 15 feet length for the washing machine waste.What I was wondering is firstly is this possible and secondly what angle should the pipe run at to drain the water but still be high enough to connect to the sink waste at the other end? |
breezer
Joined: 03 Jan 2003 Posts: 23346 Location: Sussex, United Kingdom Thanked: 5 times
Posted: Sun Sep 02, 2007 8:29 pm Post Subject: |
install a standpie direct to waste no problems, no hassle.
w/m pumpps are good at shifting volume, not pressure __________________ Do you like music Mr Finch?
Forum = Opinions |
MINSKY
Posted: Sun Sep 02, 2007 9:06 pm Post Subject: |
Hi ,Thanks for the prompt reply.Sorry for been a bit dumb but could you elaborate a bit on what you mean...cheers |
Dan_Robinson
Joined: 01 Jul 2007 Posts: 2396 Location: Hertfordshire, United Kingdom Thanked: 0 times
Posted: Sun Sep 02, 2007 9:30 pm Post Subject: |
1:40 is your magic angle, but consider using a HepVo trap instead of a standpipe - you can get fittings that reduce down to a WMC tube. __________________ Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man |
