DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Rep Radiator - Help
This topic originated from the How to page called Replacing a radiator
Click here to return to the page called Replacing a radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Arkturas
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 02, 2007 9:21 pm    Post Subject:
Rep Radiator - Help
Reply with quote Thanks
I need to replace a radiator in my bathroom, due to the fact that it’s corroded.
the dimensions are 530mm (H) x 480mm (W), Ideally want something that is the same throughout the house, I cant seem to find this type of rad anywhere, I\\\'ve tried all the major suppliers, but no-one seems to have a radiator with these dimensions, I find this very hard to believe, I live a in a new-build (8yrs) estate, the radiator would have been fitted in a few hundred homes.
Any advice would be appreciated
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Sun Sep 02, 2007 9:25 pm    Post Subject:
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Arkturas
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 02, 2007 9:45 pm    Post Subject:
Sure thing,
here you go
Back to top
 Alert Moderators
Dan_Robinson
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 02, 2007 10:45 pm    Post Subject:
It might only be 8 years old, but things change. If you have tried all your local merchants and they can't source one then you'll have to dig a little deeper and get one to fit and modify the pipes accordingly.
__________________
Regards
Dan Robinson
If I was right half as much as my wife was wrong I'd be a very happy man
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Mon Sep 03, 2007 9:46 am    Post Subject:
Although it won't look the same, Myson do the Premier HE at 438 wide. You could then add a 20mm extension to each end to make the difference up.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Radiator Size 2 140 Tue Mar 18, 2008 11:37 am
Removing radiator from combi system 2 220 Tue Mar 18, 2008 4:30 pm
leaky radiator 5 160 Tue Mar 18, 2008 8:07 am
One Radiator Stays Hot FOr Two Hours Then Goes Cold 4 280 Mon Mar 17, 2008 1:01 pm
Radiator Not Working 2 100 Sat Mar 15, 2008 7:27 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
