pinno
Joined: 03 Sep 2007 Posts: 2 Location: Staffordshire, United Kingdom Thanked: 0 times
Posted: Mon Sep 03, 2007 4:16 pm Post Subject: wood flooring on chipboard |
Hi
I'm looking to lay a solid wood floor in my downstairs rooms but the rooms all have chipboard laid on top od dpm and concrete.
what would be the best method
thanks
Pinno |
WoodYouLike
Joined: 14 Nov 2004 Posts: 6348 Location: Kent, United Kingdom Thanked: 29 times
Posted: Tue Sep 04, 2007 9:29 am Post Subject: |
What are the sizes of the boards, thickness and what's the width of the room?
In most circumstances you can install it floating on foam underlayment, glueing the T&G's __________________ You buy quality, we'll advise. You buy rubbish, we won't!
We're proud members of the BwfA. |
pinno
Posted: Tue Sep 04, 2007 9:41 am Post Subject: |
hi
the chipboard is 20 mm thick and no room is bigger than 4.5m x 4.5 m
the wood planks would be 150mm x 18mm
the whole of the downstairs is to be laid.
i've heard the stickdown underlay may be an option? |
WoodYouLike
Posted: Tue Sep 04, 2007 9:56 am Post Subject: |
If the chipboard is level and sound 3mm foam underlayment is all you need (and PVAC adhesive to glue the T&G's).
Stickdown underlayment is a good product (Elastilon, don't go for the look-a-likes) but expensive solution __________________ You buy quality, we'll advise. You buy rubbish, we won't!
