DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
NO HOT WATER. AARGH!!
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
scott6471
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 03, 2007 9:29 pm    Post Subject:
Reply with quote Thanks
I have a Servowarm back boiler that was already fitted when we moved in. The system is Gravity fed; no valves of any sort and the hot water is not pumped.
When i moved a rad recently i drained the system and refilled when complete. For some reason i now have no hot water!!
I tried bleeding the system a number of times but the lower pipe on the back of the cylinder is cold (I guess this is the return flow). The top one is hot.
Am i getting an airlock in the coil? If so how do i clear it? Any thoughts would be greatly appreciated as the kids bath is being filled by the shower at the mo!!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
rob884
from United Kingdom
Thanked: 2 times
PostPosted: Mon Sep 03, 2007 10:45 pm    Post Subject:
Maybe try draining and refilling the system?
Back to top
 Alert Moderators
scott6471
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 03, 2007 10:58 pm    Post Subject:
Hi Rob,
Thanks for the reply.
I'd already tried the re-drain method just in case i'd filled it up incorrectly. My research suggested airing the downstairs first as it fills up then the upstairs.
No joy!
Back to top
 Alert Moderators
The Baker
from United Kingdom
Thanked: 1 time
PostPosted: Tue Sep 04, 2007 6:35 am    Post Subject:
Does the system have a header tank for the heating system?
If the answers no then due to the design of the cylinder, you may need to drain the system and the cylinder before refilling, also don,t add any inhibitor.
Tim
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Tue Sep 04, 2007 8:34 am    Post Subject:
Are you sure the system has filled up fully each time?
You could try banging the gravity pipes carefully, otherwise it would mean calling in somebody to do what rob is thinking of.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
scott6471
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 04, 2007 6:37 pm    Post Subject:
Yes the system does have a header tank in the loft.
I've definately filled up completely as there is no air from any of the bleed valves, the pump or anything.
Am i right in thinking that Rob may be suggesting connecting a hose to the drain valve and then to a mains supply to force any air out? If so i'll have a go at this myself, hell i'll only have myself to blame if anything goes wrong.
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Tue Sep 04, 2007 6:58 pm    Post Subject:
Not what I was thinking that rob was thinking icon_lol.gif if you follow that, but you could try it icon_wink.gif
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Tue Sep 04, 2007 7:20 pm    Post Subject:
What they are not telling you is try and boil system up by taking the thermostat phial out of its pocket , BUT only let it boil for a short period . It will sound like someone battering the sh#te into it with a hammer. This will usually move the airlock... Are you sure it is a servowam bb as i have never seen one in 30 years
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Tue Sep 04, 2007 7:37 pm    Post Subject:
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
namsag
from United Kingdom
Thanked: 59 times
PostPosted: Tue Sep 04, 2007 8:01 pm    Post Subject:
Upto him but it is a diy forum not a trade forum dave
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Tue Sep 04, 2007 8:07 pm    Post Subject:
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
gasandoilman
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 04, 2007 8:50 pm    Post Subject:
you said u get no air from rads...
But do you get water coming out???
Is the system filling
__________________
life is not a dress rehersal-enjoy
Back to top
 Alert Moderators
scott6471
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 04, 2007 10:07 pm    Post Subject:
Hi Guys,
Thanks for the responses so far.
Apologies it is a Glow Worm BB not a Servowarm as suggested.
Yes there is water coming out of the rads when i bleed them.
As for removing the thermostat phile, i wouldn't even know where to find it let alone remove it!!. What are the possible downsides if i were to try this method?
Should i try forcing the air out first or is this method unlikely to work? From what i can understand connecting the hose should force all the air in the system out and apparently you can tell when it's done when the overflow from the header tank starts flowing; is this correct?
Thanks Scott
Back to top
 Alert Moderators
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Wed Sep 05, 2007 9:30 am    Post Subject:
All this will prove is that the hearder tank is full, not that you have got rid of the airlocks!
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Wed Sep 05, 2007 10:26 am    Post Subject:
Have you tried filling it from the bottom? F&E tank empty, hosepipe on the lowest drain-off spigot?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Water Pressure and Flow 4 260 Thu May 01, 2008 6:20 pm
Water softners / water conditioners / scale reducers 2 340 Wed Apr 30, 2008 4:12 pm
need to turn off water 15 560 Wed Apr 30, 2008 10:22 am
How do i remove a water pressure switch? 5 260 Tue Apr 29, 2008 10:59 am
Can water travel back from hot water tank into cold tank? 2 180 Fri May 02, 2008 8:27 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
