DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Electric shower switch
This topic originated from the How to page called Installing a electrical mounting box
Click here to return to the page called Installing a electrical mounting box.
  View previous topic :: View next topic
Author Message
Di
from United Kingdom
PostPosted: Wed Jun 02, 2004 8:09 am    Post Subject:
I\\\'ve got a Mira shower. The 6kV electric switch seems as though it\\\'s quite difficult to switch on and off, so I think it needs changing. The instructions manual says to use a 40 amp switch but I can only find 35amp at the shops? Can I use this or does anbody know where I can get one? TA.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
ban-all-sheds
from United Kingdom
PostPosted: Wed Jun 02, 2004 10:08 am    Post Subject:
Re: Electric shower switch
I'm not surprised - anything designed to safely switch 6kV is going to be a bit of a monster. 230V is all you need in a house.
Sorry - couldn't resist - not really taking the p*ss....
Most sheds (ugh) should stock 40 or 45A switches - where have you looked?
Or you could try an online supplier like TLC or QVS, or even an online shed like Screwfix.
__________________
I mustn't warn people that the "experts" on the plumbing forum can't be trusted to tell the truth.
Back to top
 Alert Moderators
securespark
from United Kingdom
PostPosted: Wed Jun 02, 2004 11:37 pm    Post Subject:
Ban
Does Di mean switch or mcb/fuse?
I haven't seen 35A switches, but I have seen 35A protective devices.....
Back to top
 Alert Moderators
ninebob
from United Kingdom
PostPosted: Wed Jun 02, 2004 11:44 pm    Post Subject:
Looks like we're talking about a pull-cord or outside-bathroom switch. 45A shouldn't be too hard to find, but Ban, did you really just recommend screwfix??? icon_surprised.gif
Back to top
 Alert Moderators
ninebob
from United Kingdom
PostPosted: Wed Jun 02, 2004 11:48 pm    Post Subject:
Also, having re-read the oringinal post -
I assume you mean the shower is 6 kiloWATT, using 230v gives a figure of 26 amps.
So, the 35 amp switch you have seen is absolutely fine, as long as you are sure that the unit is no more than 8Kw.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
PostPosted: Wed Jun 02, 2004 11:54 pm    Post Subject:
securespark wrote:
Ban
That's a jolly good point. Especially as an MCB might be marked with a number like 6000 or 6K, referring to its short-circuit breaking capacity....
That would mean that Di has been frequently using the MCB as an isolation switch....
__________________
Back to top
 Alert Moderators
ninebob
from United Kingdom
PostPosted: Thu Jun 03, 2004 12:22 am    Post Subject:
To clarify....
DI-
Look at the shower, or at it's instruction book. Somewhere you will see it's rating, which will either be stated in watts (anywhere between 5000 watts and 11500 watts) or otherwise termed as kilowatts, therefore anywhere between 5kw and 11.5 kilowatts. Divide the wattage by 230. The figure you come out with is the minimum (in amps) that you can use for a switch or circuit breaker.
Example: my shower here is 8.5kw (8500 watts) - divided by 230 gives me 36.95 amps. So my 40A switch and 40A breaker are fine.
Back to top
 Alert Moderators
ban-all-sheds
from United Kingdom
PostPosted: Thu Jun 03, 2004 12:47 am    Post Subject:
ninebob wrote:
Well... in a last-resort kind of way, and I did make it clear that they are an online shed....
__________________
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Electric shower switch tripped 19 3180 Tue Jun 20, 2006 11:50 am
Electric shower pull switch 8 660 Sun Jan 28, 2007 5:26 pm
Electric Shower - Isolating Switch ? 6 900 Sat Jun 18, 2005 12:32 pm
Ceiling Switch for Electric Shower 5 600 Sun Dec 04, 2005 12:04 pm
Triton T80i Electric Shower Will Not Switch Off the Water 4 880 Tue Oct 23, 2007 11:22 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
