DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Bosch - Stagnant water smell
This topic originated from the How to page called Washing machine troubleshooting
Click here to return to the page called Washing machine troubleshooting.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
d lewis
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 04, 2007 6:05 pm    Post Subject:
Reply with quote Thanks
I have a bosch washing machine, which has started to smell following a washing cycle. I have cleaned the soap dispenser drawer, but wondered if I could use a diluted solution of bleach to run through the machine. It smells of stagnant water inside the drum - wondered if I should call out a specialist to have a look at it?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Wed Sep 05, 2007 5:17 pm    Post Subject:
Yes, do a service wash( boil wash with no clothes in) also ensure there is not a pool of stagnant water or mould between the door seal & the drum.
Back to top
 Alert Moderators
d lewis
from United Kingdom
Thanked: 0 times
PostPosted: Tue Nov 13, 2007 8:10 pm    Post Subject:
Bosh Washing machine still has smell
Thanks for the reply, I have done a service wash with bleach, but still getting the smell. Do you think that something could be blocked?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Tue Nov 13, 2007 8:14 pm    Post Subject:
please describe the route the waste pipe takes between the machine and the drain (with photos if possible)
http://www.diynot.com/forums/viewtopic.php?t=99672
p.s. when you did the service wash, what temperature did you use? what temperature do you normally use?
When you took the soap drawer out to scrub it with hot water, did you also scrub out the slot in the front of the machine that the drawer slides into?
Bleach kills bacteria but it does not dissolve sludge.
Back to top
 Alert Moderators
mckcol
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 30, 2007 12:34 pm    Post Subject:
Re: Bosh - Stagnant water smell
I have a bosh washing machine, which has started to smell following a washing cycle. I have cleaned the soap dispenser drawer, but wondered if I could use a diluted solution of bleach to run through the machine. It smells of stagnant water inside the drum - wondered if I should call out a specialist to have a look at it?
Did you find a cure? My machine smells terrible - I wondered if there was something decaying between the drum and drum assembly - an old sock or something! Doesn't look too simple to strip the drum apart though..
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sun Dec 30, 2007 1:36 pm    Post Subject:
mckcol have you followed the suggestions given?
it's usually sludge build-up from low-temperature washes and excess powder and softener.
Back to top
 Alert Moderators
RobinV
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 30, 2007 11:17 pm    Post Subject:
a tip passed on to me some years ago that I regularly do is to run the machine through an empty wash cycle on its hottest setting but using some soda crystals mixed with the washing powder. The high temperature and soda cryatals help to break down the sludge and kill the bacteria that develop in them. Its good for dishwashers too (using dishwasher liquid instead of ashing powder of course). Always clear out your filter before and after doing this.
Works a treat.
Regards
Back to top
 Alert Moderators
mckcol
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 31, 2007 8:49 pm    Post Subject:
I have, and I think things are improving. Having done more research I see that this is quite a common problem. I tried a cup of bleach, followed a few minutes later by a cup of vinegar - then spent the next 30 minutes mopping up the suds coming out of the soap dispenser.. I tried a service wash today with a dishwasher tablet - I'll try other suggestions if the problem persists
Regards
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Dec 31, 2007 9:00 pm    Post Subject:
a plain MAX HOT wash, with no powder, will wash away a lot of sludge. You can put in cotton towels if you want or just run it with no clothes in there.
You should also look at the route the waste hose takes as they sometimes let dirty water flow back from the sink.
Back to top
 Alert Moderators
STUEY76
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 03, 2008 9:51 pm    Post Subject:
Definately need to do several boil washes with some washing machine descaler (aquasoftner). If really bad could be clogged right through drain hose and plastic chamber in top right corner. Messy job to remove and clean!!
Back to top
 Alert Moderators
weemax
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 31, 2009 10:45 am    Post Subject:
Hi guys I'm new here. I've found this place after searching on google because my clothes smelt stagnant today after I brought them out of the washing machine.
This post in particular has interested me because I ALWAYS have a pool of water between the door seal & drum. There is a hole there (im assuming) for it to drain away, but it never drains.
The machine has been quite smelly this past few weeks as well & has been stinking out the utility room at times.
I'm only living in the house 3 months so any help would be REALLY appreciated icon_wink.gif
Thanks guys
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Mon Aug 31, 2009 10:50 am    Post Subject:
start by following the suggestions, and answering the questions, already given.
Back to top
 Alert Moderators
weemax
from United Kingdom
Thanked: 0 times
PostPosted: Mon Aug 31, 2009 11:03 am    Post Subject:
Hi was actually wondering what relevance "also ensure there is not a pool of stagnant water or mould between the door seal & the drum" this has or basically what it means.
Is the water from there supposed to drain away? The water in mine does not drain & im wondering if it is blocked some how?
Back to top
 Alert Moderators
rocks1
from Maldives
Thanked: 81 times
PostPosted: Mon Aug 31, 2009 11:23 am    Post Subject:
two holes at the bottom of the door seal are blocked .
Back to top
 Alert Moderators
weemax
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 01, 2009 12:17 pm    Post Subject:
Well, 3 x 90 degree washes later with some soda crystals & its as good as new.
Cheers guys.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Bosch Classixx 1200 - slight musty smell! 3 4440 Thu Mar 15, 2007 3:27 pm
Hoover Performa 1100 rubber bits and smell 3 1520 Sat Jan 20, 2007 10:34 am
W/M stopped working, burnt smell 9 680 Sat Jul 29, 2006 4:18 pm
Servis W/M burning smell 2 420 Sun Oct 14, 2007 8:14 pm
Smell coming from the BACK of my fridge 9 740 Mon Nov 14, 2005 4:31 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
