DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Vokera Mynute 14se pump noise etc
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Marc T
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 06, 2007 7:10 pm    Post Subject:
Reply with quote Thanks
we moved into our flat a few months back, and inherited this old conventional boiler (without any manual as ever).
Up til yesterday, there was minor noise in the middle of the night, even though HW and CH were set to off on the programmer... nothing more than a slight groan really, so thought nothing of it.
3am this morning it started making a very loud grinding/grating noise (sounded like my neighbour was drilling the walls). I swiftly turned off the power, and then double checked this afternoon where the noise was coming from.
I'm pretty sure the pump has failed, as the noise is coming directly from it as well as a fair bit of vibration. Is this likely?
Any ideas what might be the cause of the night time running, which seems to have caused the pump to fail prematurely?
cheers in advance!
Marc
Edit: meant to say as well, the pressure is down at 0.4... when it tried to get going earlier, this went up to 0.7, but dropped again as soon as the boiler decided to give up!
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
gas4you
from United Kingdom
Thanked: 41 times
PostPosted: Thu Sep 06, 2007 7:26 pm    Post Subject:
Quite often boilers are pre-programmed to spin the pump every 24hrs to stop it jamming icon_eek.gif
Could be this.
Fan could also grind stuck.
__________________
Dave
DRL Gas Services
Back to top
 Alert Moderators
Marc T
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 06, 2007 7:31 pm    Post Subject:
Could be this.
Oh, so the night-time running might not be a fault?
I've tried to start the boiler this evening, but all I get is the loud noise before it gives up trying (pilot light comes on for 10 secs or so, before shutting off when the pump stops).
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Thu Sep 06, 2007 7:51 pm    Post Subject:
Could be this.
I dont think his boiler is that sophisticated!
Pumps fail in 95% of cases as a result of dirt in the system. He presumably has a dirty system that has worn out the bearings.
Take a sample of water and see if its clear or not!
Tony
Back to top
 Alert Moderators
Marc T
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 06, 2007 7:57 pm    Post Subject:
well it does have a proudly displayed sticker saying 'serviced 8/11/97'!
sorry if I sound a tad dim, but where's the best place to take a water sample from?
thanks for the help
Marc
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Thu Sep 06, 2007 8:34 pm    Post Subject:
Without seeing the system I can only suggest a rad valve vent or the pump screw!
Whatever you stick on a shop girl from Neasden it will not make her very "sophisticated".
I think your boiler is (over) due for a service! Vokera recommend every year!
Tony
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 18 times
PostPosted: Fri Sep 07, 2007 6:12 am    Post Subject:
Mark- GET the pressure up to 1 bar ASAP. Pressure appears to be too low. Do not jumo to conclusion that the pump is faulty. Boiler could be damaged beyond economical repair if not looked at soon and is run with system pressure this low.
Can service your boiler. Am in Bearsden.
Back to top
 Alert Moderators
Marc T
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 10, 2007 9:16 am    Post Subject:
thanks for the replies.
I checked the water, and all seems pretty clear.
I bumped up the pressure to 1 bar, and the boiler began to run almost normally (with a regular 'chugging' noise, coming from the pump it seems).
Just as I was closing everything up I noticed a drip though. This drip is coming from the pipework above the pump, behind the bulk of the unit, so I can't quite see where it's actually from.
With this drip, I'm having to raise the pressure every day or so....
EDIT: Could the drip be from the pressure relief pipe (is this above the pump at the back)? When I first turned up the pressure it crept up above 3 bar, and the safety valve popped, with the pressure dropping back down to 1 bar.
Thanks for all the help!
Back to top
 Alert Moderators
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Mon Sep 10, 2007 6:18 pm    Post Subject:
the drip could be from the auto air vent or if its coming from right behind the boiler it could be the expansion vessel or the connection to it.
another possibility is the connection to the heat exchanger leaking but i cant remember if its still back there on your model. it was on the older ones.
Back to top
 Alert Moderators
Marc T
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 12, 2007 7:17 am    Post Subject:
Cheers for the help.
Just my luck, the boiler's given up completely now! Won't even fire up (well, apart from once last night when it started up, pressure shot up to 3 bar, and it cut out again).
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 18 times
PostPosted: Wed Sep 12, 2007 7:54 am    Post Subject:
As suggested your boiler is in need of service. It will only play up if you neglect it further.
Back to top
 Alert Moderators
Marc T
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 12, 2007 10:13 am    Post Subject:
Hi DP
is it possible for you to give a rough cost for servicing the boiler? Just need to know how much to put aside etc.
Back to top
 Alert Moderators
DP
from United Kingdom
Thanked: 18 times
PostPosted: Wed Sep 12, 2007 10:19 am    Post Subject:
Not on the forum. Email and I will give details of my charges.
Back to top
 Alert Moderators
Marc T
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 12, 2007 10:29 am    Post Subject:
Thanks! I've just emailed you.
Marc
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Vokera Mynute 14se 9 220 Tue Apr 14, 2009 12:38 pm
vokera mynute 14se 4 1720 Thu May 17, 2007 5:27 pm
[b]Help ! BOILER NOISE - VOKERA 12 - 48 RSE MYNUTE[/b] 9 900 Fri Feb 25, 2005 12:58 am
vokera mynute 20e 7 4280 Thu Mar 30, 2006 8:28 pm
Vokera Mynute 28SE 2 500 Mon Oct 30, 2006 4:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
