DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
HELP changing a plug needed!!!
This topic originated from the How to page called Wiring a plug
Click here to return to the page called Wiring a plug.
Goto page 1, 2  Next
  View previous topic :: View next topic
Author Message
krazikrak
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 11:00 am    Post Subject:
Reply with quote Thanks
Hi i have a electrical item that my puppy has damaged the plug on so it needs the plug replacing. it has one of them new fitted plugs on so i have cut that off and am left with two wires I'm used to rewiring plugs but the old way using 3 wires what do i do with this one?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Fri Sep 07, 2007 11:05 am    Post Subject:
many appliances have 2 wires, many also have 3 wires. neither is an old or new way.
You have a Live and a Neutral.
Back to top
 Alert Moderators
viewer
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 11:07 am    Post Subject:
Just use the two wires. Red or brown to live pin and blue or black to neutral pin. Leave earth pin in situ. Put in a fuse to suit (look at old plug for size). HTH
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Fri Sep 07, 2007 2:13 pm    Post Subject:
and make damn sure the thing you cut off really is just a plug and not a wall wart first icon_twisted.gif
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Fri Sep 07, 2007 2:30 pm    Post Subject:
LMAO - I suppose there is a good chance some people just wouldn't have a clue!
Also, on the old plug, get some pliers and bend a pin around to prevent it being plugged in. A habbit I was taught, and have carried on doing.
Back to top
 Alert Moderators
Maxxy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 3:02 pm    Post Subject:
Or pull the earth pin out before throwing it away
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Fri Sep 07, 2007 3:07 pm    Post Subject:
Why? I would have thought that would be worse than rendering the plug / cable unusable?
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Fri Sep 07, 2007 3:12 pm    Post Subject:
NOT effective as some sockets will open with only the Live and Neutral pins being present.
If the cable is cut and cannot be removed "crush" the plug.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Fri Sep 07, 2007 3:37 pm    Post Subject:
And pointless, I was talking about moulded plugs cut off items. A removeable plug could be re-used, or the cables removed.
Back to top
 Alert Moderators
flyingsparks
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 4:31 pm    Post Subject:
I am an electrcian but have never heard of a wall wart?! What is one of them??
Back to top
 Alert Moderators
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Fri Sep 07, 2007 4:33 pm    Post Subject:
A power supply or transformer or other voltage conversion built into the plug.
Back to top
 Alert Moderators
flyingsparks
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 07, 2007 6:14 pm    Post Subject:
Got it! You learn something every day! Cheers.
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Fri Sep 07, 2007 6:57 pm    Post Subject:
It is not a common term, and I beleive more american?
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Fri Sep 07, 2007 11:53 pm    Post Subject:
Ok, a bit of a hijack but I'm thinking that the thread has died anyway.
When doing PAT testing, in most places there are a host of wall warts and these are used to power eveything from phones to printers.
But there's nothing to test.
All class 2 so no earth bond test
No fuse that can be accessed
No point in doing an IR test
Not even a supply cord to inspect
BUT it fulfils the description of a portable appliance so do i just bung an OK sticker on it and take the money and run? icon_confused.gif
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sat Sep 08, 2007 2:31 am    Post Subject:
Since PAT testing came in in 89 I've always wondered about that!!
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Display posts from previous:
Goto page 1, 2  Next
Page 1 of 2
Jump to:
advice needed - changing to a dimmer 13 800 Tue Apr 05, 2005 8:39 pm
changing plug from 2pin to 3pin 5 260 Sat Aug 22, 2009 10:25 am
Changing light switches and plug sockets 3 140 Thu Aug 27, 2009 1:14 pm
changing a thai plug for uk 4 500 Wed May 16, 2007 10:41 am
Changing plug on Thai 8 way gang socket 16 880 Sun Dec 10, 2006 11:02 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
