DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Retaining fence
This topic originated from the How to page called Different ways of anchoring the fence posts
Click here to return to the page called Different ways of anchoring the fence posts.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
brianham
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jun 03, 2004 5:20 pm    Post Subject:
Retaining fence
Reply with quote Thanks
I would like to use 9ft concrete posts with 3ft of concrete gravel boards to retain soil and a 3ft fence on top of the gravel boards. Is a 9ft post adequate and should I use any special method to put the posts in to take the weight of the soil?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Sat Jun 05, 2004 5:49 pm    Post Subject:
Difficult one to answer, if the soil is level then you might get away with it then depend how much rain in the short peroid of time. I have a 9' concrete post and now have a hairline crack at the soil level due to the wind pushing onto the fence panels over the years.
It would be best to build a 9" wall thickness (double skin) with the concrete post built inside the walls to retain the soil pressure.
Back to top
 Alert Moderators
david and julie
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jun 05, 2004 9:54 pm    Post Subject:
I have seen fence posts in windy places that were 6x6 instead of the usual 4x4?. Don't know where they come from though.
Many of the smaller garden shed and fence suppliers cast their own posts, and bases. I would try and find and talk to one of those places if possible, perhaps half an hour in yellow pages under fence manufacturers?
An industrial fencing suppliers may also be worth a try.
Back to top
 Alert Moderators
mr_bigben1
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 21, 2005 8:09 am    Post Subject:
Retaining fence
The technique of using gravel boards spanning between post to retain soil is call a "Berlin Wall" in the construction industry. The principle is that the active earth pressure on the boards and the wind loading on the fence above is resisted by the passive earth pressure in front of the buried section of the posts.
The posts must be surrounded in sufficient concrete (at least 60cm diameter) in order to transmit the loads into the soil in front. The length of the post in the ground depends on the type of soil but the penetration must be AT LEAST equal to the retained height of soil and if the soil is poor, then a penetration of twice the retained height will be needed.
It will be probably be easier and more certain to build an independent 25cm gravity wall on a concrete footing between the posts as a previous member has suggested.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Rendering an outside retaining wall 2 1120 Sat May 03, 2003 10:19 am
Max. Fence height ??? 3 3260 Sun Apr 16, 2006 6:46 pm
Who owns the fence? 8 15800 Sat Oct 08, 2005 10:33 am
Boundary fence 4 1320 Thu Jul 28, 2005 12:24 pm
FENCE POST ANCHORING 7 10760 Fri May 12, 2006 8:21 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
