DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Lights and MCB's
This topic originated from the How to page called Miniature circuit breakers (MCBs)
Click here to return to the page called Miniature circuit breakers (MCBs).
  View previous topic :: View next topic
Author Message
Doofa
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 08, 2007 3:02 pm    Post Subject:
Lights and MCB's
Reply with quote Thanks
I am finding that I am getting through a large amount of light bulbs, even high quality expensive ones that are advertised as 1500hr + lifespans are lasting sometimes hours or days. Whenever one of the bulbs goes, the MCB related to that ciruit (one for upstairs, one for downstairs ) trips, this happens everytime.
Do you think there is a fault in the wiring or is there anything I can do to maximise the life of the bulbs (apart from leaving them off! icon_razz.gif )?
They are running off Hager 6A Type 2 M6 MCB's. There is no RCD that I can see.
Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
GaryMo
from United Kingdom
Thanked: 18 times
PostPosted: Sat Sep 08, 2007 3:08 pm    Post Subject:
It's a general characteristic.
A type B MCB will trip at between 3-5 x In, so for a B6 that'll be between 18 and 30A.
When a filament is ready to go for a split second there will be a surge in current will trip the MCB.
Depending on cable sizing and conditions you may be able to uprate your B6 MCB's to B10. This will probably solve the problem.
Another way would be to swap the B6's for C6's ( 5-10 x In), as long as the circuit can meet the lower maximum loop impedance figures.
Back to top
 Alert Moderators
breezer
from United Kingdom
Thanked: 5 times
PostPosted: Sat Sep 08, 2007 3:09 pm    Post Subject:
the lamps you have brought are not good qaulity, since as you say the mcb tris.
good qaulity lamps have their own internal fuse
__________________
Do you like music Mr Finch?
Forum = Opinions
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 0 times
Are they the correct lamps for the fittings? Are they inserted correctly? Are the contacts of the light fittings corroded/worn so they have a high resistance and generate excessive heat? What type/brand of lamps and what type of fittings are you using (LV or ELV?)?
Back to top
 Alert Moderators
luminaire
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 08, 2007 3:11 pm    Post Subject:
What is the load on that circuit? Have you got anything else on that circuit apart from light bulbs?
What size bulbs are they, and do you have dimmers on there?
Back to top
 Alert Moderators
Doofa
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 08, 2007 3:29 pm    Post Subject:
Are they the correct lamps for the fittings? Yes
Are they inserted correctly? Yes
Are the contacts of the light fittings corroded/worn so they have a high resistance and generate excessive heat? No most are new.
What type/brand of lamps and what type of fittings are you using (LV or ELV?)There are various (no LV/ELV) all 240v between 40 and 100W.
What is the load on that circuit? Not sure what the exact load is but we havent added any additional light points
Have you got anything else on that circuit apart from light bulbs? No
What size bulbs are they, and do you have dimmers on there? betwenn 40W and 100W and yes we have a dimmer swicth in the sitting room but not upstairs
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Sat Sep 08, 2007 5:18 pm    Post Subject:
OK, I would suggest you measure the voltage on the circuit. If its below 240 volts, (which it should be - the absolute maximum is 250 volts but this is pushing it)
You say most of the fittings are new - Perhaps they were a fault batch.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Sat Sep 08, 2007 5:23 pm    Post Subject:
the other thing you can do is fit Compact Fluorescent Lamps (Energy Saving bulbs). These last much longer, use much less electricity, make the lamp fittings last longer as they run cooler, are tolerant of voltage fluctuations, and will not trip your MCB when they fail.
It will save you a lot of time up your stepladder too.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Ceiling lights + loft insulation 3 840 Mon Feb 04, 2008 11:28 am
External Deck lights 2 240 Sun Feb 03, 2008 3:38 pm
Earth and Lights? 5 160 Sat Feb 02, 2008 6:03 pm
12v lights: resistive inductive dimmer ? 3 140 Thu Feb 07, 2008 11:50 am
Plinth lights and under cabinet lights 4 640 Thu Feb 07, 2008 4:50 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
