DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Dimmer install Query
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
goose0211
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 09, 2007 4:39 pm    Post Subject:
Reply with quote Thanks
I was about to install a dimmer to replace a single switch running 3 lights in one room, took the face plate off and found that 2 red (live) wires go into the switch in COM and 1 into L1 and the 3 black (neutral) joined and not connected to the switch, and nothing into the L2 - my dimmer has an L1 and L2 - how should it be wired??
Do I have the correct dimmer switch?
thanks for your help
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sun Sep 09, 2007 4:50 pm    Post Subject:
Does your dimmer really only have L1 and L2 terminals, or does it infact also have a ~ (with an arrow through it) terminal aswell?
__________________
I downlights
Back to top
 Alert Moderators
goose0211
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 09, 2007 5:56 pm    Post Subject:
Sorry - it actually has an L and ~ with the arrow - my mistake
Back to top
 Alert Moderators
Moderator 8
Moderator Comment
Posted: Sun Sep 09, 2007 9:34 pm    Comment:
Sorry TTC I accidentally deleted your post.
Space cat
from United Kingdom
Thanked: 3 times
PostPosted: Mon Sep 10, 2007 7:46 am    Post Subject:
Hopefully there are also some earths in there!
Leave the earths and neutrals as they are. The single red wire from L1 goes to one of your dimmer terminals and the two from COM go to the other. It will work either way round but, for the benefit of the next person who opens up the box, you should put the permanent live(s) into L. Since the existing switch controls multiple lights, the two red wires in COM are probably the switched ones. If you want to be sure, a meter or neon driver will tell you.
__________________
Their base is so secret, even the space cats don't know where they are.
Back to top
 Alert Moderators
goose0211
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 10, 2007 8:57 am    Post Subject:
Thanks for your reply - I shall give that a go, and yes there are earth's in there connected as suspected to the mounting plate.
Thanks for your help
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Hi all interesting install query 29 860 Sun Aug 31, 2008 3:34 pm
Help please with 2-gang 1-way dimmer switch install ... 5 500 Sat Nov 19, 2005 8:23 pm
dimmer swicth install problems 7 240 Sat Sep 12, 2009 6:04 pm
How to install a dimmer switch on a 3 Way curcuit. 5 360 Wed Aug 13, 2008 12:22 pm
Dimmer Switch - How to install 11 300 Mon May 11, 2009 5:10 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
