mgramp
Joined: 10 Sep 2007 Posts: 2 Location: United States of America Thanked: 0 times
Posted: Mon Sep 10, 2007 12:49 pm Post Subject: Washing Machine |
My washing machine goes through the initial wash step fine. I can hear the timer prior to it getting to the rinse cycle. The drum does not empty the water at any time. It will not go to rinse cycle. If I turn off machine and reset it to the rinse setting, it works again. At no time can I get the spin cycle to work, nor can i get the machine yo run completely through wash, rinse, spin.. any suggestions as to what may be causing this problem? Thanks in advance for any help.[/i] |
jj4091
Joined: 01 Dec 2006 Posts: 1794 Location: Cumbria, United Kingdom Thanked: 8 times
Posted: Mon Sep 10, 2007 5:05 pm Post Subject: |
Sorry not phsycic. Make & model? |
mgramp
Posted: Mon Sep 10, 2007 5:13 pm Post Subject: sorry |
I suppose that info would help,, sorry i did not include in first message. Whirlpool Ultimate Care II,,, also on tag inside door,, mod info is LSQ8543JQO.... i hope this helps,,, machine fills, agitates but when it is time to drain it appears that it does not get into that step. I can hear the timer but it will not go to draining step after timer stops ticking,, thanks for responding, any info you can suggest is appreciated |
dumbfounded2
Joined: 03 Dec 2007 Posts: 1 Location: United States of America Thanked: 0 times
Posted: Mon Dec 03, 2007 10:38 pm Post Subject: |
If you are still having the problem, check the lid switch. I had whirlpool washer and it had the same problem. I hired a repair man and he changed that and the machine is now working. The problem is normally caused by the lid cover being banged. |
