JARLATH
Joined: 10 Sep 2007 Posts: 2 Location: Middlesex, United Kingdom Thanked: 0 times
Posted: Mon Sep 10, 2007 3:29 pm Post Subject: INSTALLING DOUBLE OVEN |
Have just installed De Dietrich double electric oven. Would appear to have installed correctly because when main fuse switch is pressed on then the top oven, fan, light etc, powers on. Alas nothing happening with main bottom oven and digital display not showing anything which its supposed to when first switched on. Any ideas? |
megawatt
Joined: 03 Sep 2005 Posts: 3170 Location: Devon, United Kingdom Thanked: 1 time
Posted: Mon Sep 10, 2007 4:00 pm Post Subject: |
If you have supply at it's main terminals call the manufacturer as its under warranty and anything else you do will invalidate it.
MW |
bernardgreen
Joined: 03 Nov 2006 Posts: 3611 Location: Bedfordshire, United Kingdom Thanked: 22 times
Posted: Mon Sep 10, 2007 4:08 pm Post Subject: |
There may be two LIVE terminals where the cable is connected to the oven. LIVE 1 LIVE 2 NEUTRAL and EARTH
For a UK single phase supply the two LIVEs need to be connected. A horse shoe or "U" shaped link may have been provided.
Look at the installation instructions to see if this is the case with your oven. |
JARLATH
Posted: Wed Mar 19, 2008 7:28 pm Post Subject: |
Very late thank you
Yes, the u-shaped link was missing and onc efitted solved the problem immediately |
