Hole in Internal Breeze block wall - How to fill?
7 Sep 2007
London
Hi, I hope that this is in the correct forum - apologies if not.
Having got a new boiler in a different location in the house, I have since had the 1970's Asbestos-Cement flue removed from the house. At one point this went horizontally through an internal (breeze-block) wall (Cupboard to Bathroom) before continuing vertically to the ceiling.
I now have a hole in the breeze-block about 7-8 inches diameter which I need to fill - what is the best way of doing this? Given that one side of the wall is in a cupboard, I considered screwing a board to that side, and filling the majority of the hole with expanding foam and then covering with plaster. Thoughts and Comments appreciated. Cheers
Get another breeze block and cut it to fit, they are really easy to cut using an old saw. Then mortar it in. The foam thing would work but could end up a disaster, that expanding foam is messy stuff.
i would follow the above advice, adding only to say, damp both the block and the location with water first.
Thanks for the advice... guess I'll have to go and see what the smallest number of breezeblocks I can buy is... presumably not a single one :(
you can buy 1 if thats all you want or be cheeky and ask if you can have one for a sample
Thanks for all the advice - bought a single breeze block (got some odd looks both at the builders merchant and on the bus home though ;) ) and cold chiselled it to the right size rather than saw, but other than that it worked great as suggested.
You can often get a free sample from those steel display cabinets positioned at the side of the road outside a house where building work is being done.
