DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
hotpoint aquarius wf740 saying f-04.. pleaseee help x x
This topic originated from the How to page called Washing machine troubleshooting
Click here to return to the page called Washing machine troubleshooting.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
emzi26
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 11, 2007 3:06 pm    Post Subject:
Reply with quote Thanks
hi i hope someone can help i went to do the washing when the time got down to 27 mins it stopped working there was a few weird noises before and it came up on the screen f-05 so i turned it off then put it back on to rinse and spin it rinsed it but then it said f-04 so now i have a washing machine full of water and clothes can someone help pleaseeee x x
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mikeyd
from United Kingdom
Thanked: 3 times
PostPosted: Wed Sep 12, 2007 2:57 pm    Post Subject:
No idea how to fix a washing machine, but I do have a list of fault codes:
F04: possible filling or water level problem. Check water inlet pipe (or shut-off valve), or the outlet pipe, or the pump or pump filter if accessible (check for blockages or foreign objects). Also could be the water valve solenoid weak, causing filling to be too slow.
F05: possible draining (pumping off) problem, check the pump filter, or pump, outlet pipe, or U-BEND.
My guess would be the pump and or filter possibly blocked as it is common to both fault codes.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
Hotpoint WF740 - Major Leaking 45 2120 Fri Feb 13, 2009 7:05 pm
Hotpoint Aquarius WD420 Error Code? 7 1220 Sat Feb 14, 2009 7:29 am
Hotpoint Aquarius Extra wma40n brushes 17 700 Sun Feb 22, 2009 12:13 pm
Hotpoint Aquarius CTD00 T/D 13 3020 Wed Oct 18, 2006 7:38 pm
Hotpoint Aquarius CTD00 makes humming noise does not dry 3 2960 Tue Oct 24, 2006 7:23 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
