DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitting a terminal outlet box
This topic originated from the How to page called Installing an electric cooker
Click here to return to the page called Installing an electric cooker.
  View previous topic :: View next topic
Author Message
scotsman46
from United Kingdom
Thanked: 0 times
PostPosted: Wed Sep 12, 2007 5:45 pm    Post Subject:
Reply with quote Thanks
Hello, I am getting a new electric cooker installed,
The old cooker was connected by just having the cable from the control unit conected to the cooker directly with the wiring joined together and tape over it.
I know I need a terminal outlet box.
Can I fit this Directly behind the cooker?
I have about 18inches of cable from the control unit coming out the wall behind the cooker so the new terminal box would be about 12 inches below the hob level behind the cooker.
I just want to know if that is legal
Comet are delivering the new cooker and connecting it and I do not want them to say they can not connect it due to the box being in wrong place
Thank you for any comments
Mike
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Space cat
from United Kingdom
Thanked: 3 times
PostPosted: Thu Sep 13, 2007 7:58 am    Post Subject:
If you can get hold of the installation instructions for the cooker before it arrives it might have a recommended position for the box. Try the manufacturer's web site - if they've got one.
__________________
Their base is so secret, even the space cats don't know where they are.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu Sep 13, 2007 8:26 am    Post Subject:
you can put the cooker outlet behind the cooker.
They are usually about 450mm above floor level. The higher it is the more it is likely to be heated by waste heat from the oven.
They can be recessed into a metal wall box recessed into the wall so they do not protrude. Due to the thickness of the wires the box is quite deep so a surface one would stick out and might prevent you pushing the cooker back to the wall. When chasing out the hole start just past where the cable comes out so that you do not risk damaging it.
The outlet does not have to be directly behind the cooker but if not should be fairly close. The cable, where chased into the wall, should run directly vertically or horizontally from the control switch - diagonal or bent runs are not permitted unless you provide a lot of protection which is fairly impractical.
Back to top
 Alert Moderators
plugwash
from United Kingdom
Thanked: 15 times
PostPosted: Thu Sep 13, 2007 8:31 am    Post Subject:
Since it's going to be hidden behind an appliance you could just surface clip it and avoid the whole permitted routes issue completely.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Thu Sep 13, 2007 8:35 am    Post Subject:
true
(scotsman46 - the reason for the straight runs is so that people can later forecast where the cable is likely to be so they don't drill or nail into it. As plug says, if the cable is visible thsi is not very likely)
Back to top
 Alert Moderators
scotsman46
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 13, 2007 4:35 pm    Post Subject:
Many thanks for the replies.
The box will have to be fitted about 700mm from floor level which will be approx 200mm down from the top of cooker due to the length of the existing cable coming through the wall from the control unit.
I will let you know how I get on.
Mike
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Terminal Outlet Box 2 620 Wed Jan 10, 2007 2:43 pm
moving a cooker terminal outlet? 3 800 Sun Sep 09, 2007 9:26 am
terminal outlet box 3 3240 Sat Jul 14, 2007 5:29 pm
Separate hob, double oven-terminal outlet required? 2 980 Mon Jul 18, 2005 11:47 am
terminal outlet boxes 2 2280 Wed May 17, 2006 6:09 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
