catbrady
Joined: 12 Sep 2007 Posts: 4 Location: United Kingdom Thanked: 0 times
Posted: Wed Sep 12, 2007 6:49 pm Post Subject: smelly drains |
Hi
We have really bad sewer smells coming from the outside drain where are bath and sink water go. The smell comes intermittently after usage. I have cleared the drain of debris. There is no blockage according to DynoRod. We are at a loss - help please! |
Nige F
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
catbrady
Posted: Wed Sep 12, 2007 8:08 pm Post Subject: |
Thank you Nige F - being a DIY dimwit - how would I check out if what you suggest might be the case? |
Nige F
Posted: Thu Sep 13, 2007 10:54 am Post Subject: |
have a look round the property for a pipe out thru roof or standing up side of house....provided you`ve not got a fan in the bathroom that can be thru a similar pipe  ........ideally you need a plumber who can look and identify, or even put a smoke test on the drains..that`ll show it up  Good luck in finding one who`s not corgi, and charges £££££££because he`s gas qualified  |
catbrady
Posted: Tue Sep 18, 2007 10:19 am Post Subject: |
Thanks Nige F. Two plastic pipes come out of the bathroom wall and into an open metal pipe which runs about 2m down the wall to an open drain. Out plumber suggested sealing the open drain. But we worry that that might force the smell up into the bathroom?
Do you think we should seal the open drain? |
Gees
Joined: 19 Apr 2003 Posts: 550 Location: Durham, United Kingdom Thanked: 1 time
Posted: Tue Sep 18, 2007 3:18 pm Post Subject: |
I had a similar problem here. I eventually got the big rubber gauntlets on and " dug out " the trap in the drain by hand....( very smelly )
Then a flush out with fresh water and jeyes fluid... Nice and clean now...Not a trace of smell..  |
catbrady
Posted: Wed Sep 19, 2007 1:30 pm Post Subject: |
Thanks - we tried that but the smell comes back. If we haven't used the bathroom sink or bath for a few hours then when we use it the smell comes pouring out of the drain. It smells like sewage. |
