DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
potterton HE Powermax lock outs
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Diane Jane
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 14, 2007 7:24 pm    Post Subject:
Reply with quote Thanks
Can anyone help please please?
I have a 3 year old potterton powermax H.E 115 condensing boiler. The pressure falls down every day and the control panel displays p0.5 or p0.9 so I bring it up to the right one. However lately the system locks out and the panel displays A 01 error so I reset it but it is repetitive and i'm fed up with this. I believe the low pressure indicates a leak somewhere ... am i right ? how do I go about correcting the matter ?? Please help. I have a new baby and cannot afford to have a freezing house this winter. Can't afford much now as I'm on maternity leave so I need to try to fix the problem myself if possible. Diane
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Fri Sep 14, 2007 8:05 pm    Post Subject:
You might need to go on a crash plumbing course!
Basically you need to find where water is leaking from your boiler or heating system.
It could be underneath the floor so a crash carpentry course might also come in useful.
Tony
Back to top
 Alert Moderators
corgigazza
from United Kingdom
Thanked: 5 times
PostPosted: Fri Sep 14, 2007 8:11 pm    Post Subject:
these biolers are complicated and a lot of gas engineers dont like fixing them, the fault is ignition lock out this would need looking at by corgi engineer, the loss of presure is down to a leak somewere that would need a full inspection, u could possibly try british gas or baxi to repair. (or local engineer with knowledge of them)
sorry not a diy fix
Back to top
 Alert Moderators
Diane Jane
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 14, 2007 8:24 pm    Post Subject:
Thank you Tony and Corgigazza for prompt reply. I thought this was not a DIY ... what a shame !! I'll probably have to call Baxi out .. Any ideas how much it would cost ? Sorry but I'm very skinned at the moment !! If there is a leak ... would they be able to locate it and fix it ? what about if it's under the floor ? I can't imagine they'll be able to do anything about this !! Thanks. Diane
Back to top
 Alert Moderators
ollski
from United Kingdom
Thanked: 10 times
PostPosted: Fri Sep 14, 2007 9:09 pm    Post Subject:
Personally I would honestly say that bg were a better bet than baxi as they will at least llok at pipework wheras baxi will only look at their appliance and nothing else. Although saying that my money would be on a recharge / replaced expansion vessel. Try to trace the pressure relief / overflow pipe outside and put a dish under it to see if it's dripping.
__________________
no to pointless signatures
Back to top
 Alert Moderators
dmitch071
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 14, 2007 9:25 pm    Post Subject:
I would agree, if you go with Baxi they will only look at the appliance. BG will look at they whole system so you could get the leak and boiler problem sorted, rather than pay baxi to look at boiler then someone else to look at pressure drop.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Sat Sep 15, 2007 12:15 am    Post Subject:
You can check the PRV vent yourself as well as all the radiator valves.
A competent local boiler engineer will probably be far cheaper than BG or Baxi and the problem is less likely to be in the boiler itself.
Tony
Back to top
 Alert Moderators
Diane Jane
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 18, 2007 1:44 pm    Post Subject:
Thanks to all.
Very strange. I switched the boiler on after it had been off for a while, And it didn't lock out, but instead the pressure kept playing up. Rising and then dropping then rising again. so could this indicate that there is no leak but perhaps a different problem ? Please help. This boiler is driving me nuts !! Will never recommend it to anyone !!
Back to top
 Alert Moderators
poxi
from United Kingdom
Thanked: 2 times
PostPosted: Tue Sep 18, 2007 6:07 pm    Post Subject:
Diane Jane wrote:
Thanks to all.
No..The flexible pipe to the expansion vessel is probalay blocked with crud or the x vessel itself is holed.
Back to top
 Alert Moderators
Diane Jane
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 23, 2007 11:17 pm    Post Subject:
Thanks. Questions to Ollski and Poxi please
Ollski....... I did like you suggested, and the overflow pipe outside is dripping, so does this mean there is a leak in the system? Or do you think changing the pressure relief valve may solve the problem?
Poxi....... I took out the expansion vessel and cleaned and checked the flexible pipe to it. is not blocked and the expansion vessel looks fine too. Do you think it is worth replacing it with a new one? or would I be wasting my money?
What should I do next... very last thing before having to call out someone as I'm very skinned at the minute ?
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Sun Sep 23, 2007 11:23 pm    Post Subject:
You should see if you can pressurise the EVX while its out.
If it pressurises put 0.9 Bar of ain in it.
I have this suspision that its leaking and will not pressurise!
If so you need a new one for a start.
Tony
Back to top
 Alert Moderators
Reinier Kramer
from United Kingdom
Thanked: 0 times
PostPosted: Wed Oct 31, 2007 2:34 pm    Post Subject:
I have exactly the same problem as Diana Jane.
A Potterton Powermax HE 115 system which discarts water.
I had a plummer to fix it suggesting that i suspected the expansion vessel needed replacing because the pressure went up to high after start up.
THe plummer ignored this suggestion and replaced the 3 bar pressure valve. The result is that i still have the same problem.
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 193 times
PostPosted: Wed Oct 31, 2007 11:42 pm    Post Subject:
Well if you engage an incompetent plumber ( or plummer if you must spell it like that ) rather than a boiler engineer then what do you expect?
I hope you did not pay the arrogant muppet?
Tony
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
OIL HEATING LOCK OUTS 9 240 Fri Aug 14, 2009 10:56 am
Worcester programmer pin-outs 3 800 Thu Sep 14, 2006 5:59 am
Ideal Icos HE15 starts then flame outs? 26 940 Thu Feb 26, 2009 10:01 pm
Baxi solo 2 pf 30 cuts outs for 106 secs 2 140 Sat Feb 28, 2009 10:30 pm
Powermax 155x Low Pressure Lock Out 4 800 Thu Feb 14, 2008 8:05 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
