DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
crack in ceiling
This topic originated from the How to page called Preparing Walls and Ceilings
Click here to return to the page called Preparing Walls and Ceilings.
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
haveago!
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 16, 2007 12:22 pm    Post Subject:
crack in ceiling
Reply with quote Thanks
Please help Have had it plastered, they glued what looked like fiber mesh over the crack that goes from one end of the kitchen ceiling to the other and then plastered the whole ceiling. Couple of weeks later the crack came back! What is causing this, and can i fix it myself? icon_wink.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
roughcaster
from United Kingdom
Thanked: 49 times
PostPosted: Sun Sep 16, 2007 9:47 pm    Post Subject:
Hi and welcome to the forum,
I'm taking it for granted that your ceiling is made of plasterboard.Most cracks that run straight are caused by the joints in the boards.Push up on the ceiling along the length of the crack and see if there is any movement in the boards.If there is, you will need to put 1.5"screws into the joists,either side of the crack,along the whole length of it,and see if that helps.This is the root of your problem.To put a piece of flimsy fibre tape over it and cover it with probably a thin coat of plaster without doing that first, was a waste of time and money,and would never really work.....Apart from tightening up the boards,I don't think you could fix the ceiling yourself.I think you would need a plasterer to come in and do it all over again,(if you wanted that) but this time use 4" wide jute scrim to cover the crack,then cover the whole ceiling with British Gypsum bonding-coat.This is undercoat plaster, apply 2 coats.The scrim would be bedded into this undercoat plaster along the whole length of the crack.When all of this has set,the ceiling would get 2 coats of multi finish.This might seem a fair old thickness of plaster overall,but it is only 5-6 mm, if that.You will get a far stronger job.I do it this way all the time.You would need to PVA the ceiling of course before any plastering takes place.The plasterer would do this on the day.The whole plastering side of your job should be done in a day, and the key to the success of your job,are the screws,and a decent plasterer.
Roughcaster.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Page 1 of 1
Jump to:
crack in ceiling 5 540 Fri Nov 28, 2008 10:10 am
Ceiling Crack 10 4040 Tue Oct 23, 2007 8:48 pm
Crack appeared in ceiling artex 5 1260 Wed Jan 02, 2008 10:56 am
crack in newly plastered ceiling 4 840 Sat Feb 04, 2006 12:05 pm
crack in ceiling 2 1220 Thu Sep 16, 2004 12:20 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
