Joined: 03 Sep 2007 Posts: 6 Location: United Kingdom Thanked: 0 times
Posted: Sun Sep 16, 2007 9:15 pm Post Subject:
Seized backnuts
I'm trying to replace two 1/2" basin taps but can't undo the backnuts with a basin spanner. They're very tight and I can't put a lot of pressure on the spanner because it starts to turn on the nuts.
I thought of trying a hacksaw but I can't get it up to the nut because of the recess in the bottom of the basin.
Joined: 06 Mar 2003 Posts: 1496 Location: Manchester, United Kingdom Thanked: 10 times
Posted: Sun Sep 16, 2007 10:31 pm Post Subject:
I think you need a good basin wrench that will not slip off, but even then you will most likely find you can't stop the tap itself from turning.
I have a short piece of timber with a recess cut into one end to accomadate the spout of the tap to prevent it from turning.
You may try putting timber between tap spout and wall to prevent turning.
Also try WD 40 and leaving to soak in.
Another tool to use instead of the basin wrench would be a box spanner.
You will have to push pipe to one side a little but it can't slip.
With enough force on both spanner and tap it will move.
When you get a small movement,stop and turn it back a bit, then repeat the operation. It helps loosen it and allows WD 40 to creep a little further.
Joined: 26 Jun 2004 Posts: 24304 Location: London, United Kingdom Thanked: 191 times
Posted: Mon Sep 17, 2007 11:10 pm Post Subject:
[quote="Softus"]
Agile wrote:
Seriously. Have you ever actually done any plumbing?
I say often enough that I repair boilers.
Plumbing is for plumbers!
Just as well as there are so many problems that can arise with anything even as simple as a tap!
Like having to remove a bath to undo a bath tap!
As I understand boilers then they are simple and less things to go wrong.
If I wanted to do plumbing then I could do it but then I would be up against the east Europeans who do it cheaper. At least I know with boilers that not many people understand them.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
