DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Fitted a spur from Junction box but no power.
This topic originated from the How to page called Adding a spur to a ring circuit from a junction box
Click here to return to the page called Adding a spur to a ring circuit from a junction box.
  View previous topic :: View next topic
Author Message
m900349
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 17, 2007 11:53 am    Post Subject:
Reply with quote Thanks
Hello!
Bought my first house a few months ago and I'm fitting my first new double socket in the spare room.
My issue is that I thought I had correctly connected the socked to the junction box there was no power. Other devices pluged in to the ring main function as expected (drill etc). Uprooting the floor boards determined that there is a junction box in the landing, all I have done is run a cable from the new socket in the wall into the junction box. I can't understand why there is no power to this; (although I have assumed that its okay to take the spur from this - maybe I've broken the ring).
Could anyone have any suggestion? I'm new to all of this so please bear with me icon_smile.gif
Many thanks, Johno.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
viewer
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 17, 2007 11:57 am    Post Subject:
Did you check that there is power to the junction box and that it is a part of the ring circuit? It's not unusual when rewiring for electricians just to leave old wires and JBs.
V
Back to top
 Alert Moderators
m900349
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 17, 2007 12:02 pm    Post Subject:
I did not check that - as I guess this is the first time venturing in to home electrics I assumed that every cable was live... icon_redface.gif
I'll pop by B&Q and get one of those electrical testing screw drivers and see if there is power to that circuit, if not I'll look to find a live wire and fit a junction box to this.
If that's the case, I know you can run a spur from another socket, is it recommended to place a new junction box on the live wire or create a spur from the socket.
Back to top
 Alert Moderators
mdbalson
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 17, 2007 12:15 pm    Post Subject:
Do not get a Neon screwdriver as they are unrelieable, get a mutimeter instead.
You can spur from the back of a socket if it is part of the ring, & does not have a spur coming from it already.
Back to top
 Alert Moderators
davy_owen_88
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 17, 2007 12:16 pm    Post Subject:
NOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Buy a multimeter. You can get them for less than £10 and they will actually be accurate, and useful.
Back to top
 Alert Moderators
mdbalson
from United Kingdom
Thanked: 0 times
PostPosted: Mon Sep 17, 2007 12:21 pm    Post Subject:
Too slow davy_owen_88
Back to top
 Alert Moderators
sm1thson
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 18, 2007 3:52 pm    Post Subject:
spur from a socket! junction boxes are evil, and you need to leave them accessible (not buried under the floor) as the screws loosen with time, so far better to go into an existing socket (also that way you wont end up tapping into the wrong circuit!)
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Tue Sep 18, 2007 4:15 pm    Post Subject:
Today's bargain £5.99 from maplin http://www.maplin.co.uk/Module.aspx?ModuleNo=37279&C=Maplin&U=SearchTop&T=MULTIMETER&doy=18m9
AND its buy one, get one free!!
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
notb665
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 18, 2007 4:56 pm    Post Subject:
Come on, the bloke should not be doing this - he doesn't have the foggiest.
A random JB he found and no mention of cable sizes!
I'm not a professional but others (professionals) on here have berated and admonished for far better than the original post.
__________________
I may not be a lady, but I'm all woman.
Back to top
 Alert Moderators
dingbat
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 18, 2007 6:04 pm    Post Subject:
I made a sort of resolution, that if I couldn't say something helpful I wouldn't bother posting (which is one reason I've been so quiet of late!) but on this I agree absolutely with notb665.
If this is not a wind-up then the OP should not be attempting this job.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Power to new bedroom units with fitted downlighting 3 360 Mon Oct 30, 2006 5:33 pm
Flush fitted meter box 9 600 Tue Jan 08, 2008 9:13 pm
Want new CU fitted, will old circuits require updating? 7 600 Thu Jan 10, 2008 2:08 pm
had a shower fitted is this safe! 22 1440 Sun Jan 13, 2008 10:46 am
Electrician-fitted part-load consumer unit. 11 700 Wed Jan 02, 2008 3:01 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
