Joined: 17 Sep 2007 Posts: 9 Location: Lincolnshire, United Kingdom Thanked: 0 times
Posted: Mon Sep 17, 2007 10:42 pm Post Subject:
Two Gang lighting for garage
I would like to install two flourescent lights in my garage each independently controlled from one two gang two way light switch. The switch i have has one common and one L1 and 1 L2 on each switch. cananyone please help me and explain the correct way to connect these lights from my 6 amp mini circuit breaker in my garage consumer unit all the way through to the lights and switch.
Posted: Mon Sep 17, 2007 10:53 pm Post Subject:
many thanks i had happened accross the forum by seeing questions on the bottom of a diynot page and didnt realise there was an actual forun head until i was brought to the forum after i had signed up and posted. apologies for time-wasting.
Posted: Sat Sep 29, 2007 8:08 pm Post Subject:
I have reviewed the FAQ and just want to check something- i am using a two gang switch in a single back box- is it possible to jump across the permanant live to the second common so that i can run just one cable from the switch to the first flourecent strip light and then run a second cable with the switched live across to the second flourescent strip light?
Yes - the permenant live is fed to both COMs. The two switched lives go to the two L1s.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
