Joined: 18 Sep 2007 Posts: 2 Location: United Kingdom Thanked: 0 times
Posted: Tue Sep 18, 2007 6:44 pm Post Subject:
Aquarium electrics
Hi, Im looking for some kind of switch for my water pump, that when there is a power cut or somthing like that, and the power goes back on, i want the pump remain off, i wish to switch it back on manualy if i can ? Does such a switch exsist ? thnx
Joined: 30 Jul 2006 Posts: 1873 Location: Hampshire, United Kingdom Thanked: 20 times
Posted: Tue Sep 18, 2007 7:52 pm Post Subject:
Sounds like a contactor with a no volt release, as used for motor starters. They are often used on machine tools etc. where you don't want them to re-start unexpectedly.
It's basically a relay, with the coil energised through it's own contacts, and a couple of push button to operate it initially.
If the power fails the relay releases and switches the circuit off. It can only be turned back on by operating the push button.
Joined: 11 Jul 2006 Posts: 380 Location: West Glamorgan, United Kingdom Thanked: 0 times
Posted: Tue Sep 18, 2007 8:16 pm Post Subject:
Or you could just buy a PowerBreaker RCD plug (see pic below), when the power to them fails you have to manually re-set them to get the power back on. Much easier as you only need to change the plug then, assuming your pump is currently fed from a plug of course.
Joined: 15 Apr 2005 Posts: 12852 Location: Yorkshire, United Kingdom Thanked: 22 times
Posted: Tue Sep 18, 2007 8:33 pm Post Subject:
Is this 100% guarranteed that it wont re-energise after a powercut??? I thought it was normally a game of chance with these RCD plugs.
Joined: 07 May 2007 Posts: 1457 Location: Lincolnshire, United Kingdom Thanked: 23 times
Posted: Tue Sep 18, 2007 9:19 pm Post Subject:
Depends very much on the type you buy. I've always found the powerbreaker ones with the 'horizontal blinds' indicator window to need a manual reset after removing power.
__________________ Matthew
"I told you, I only wrote that poem to test my printer!"
Joined: 27 Jul 2006 Posts: 4938 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Tue Sep 18, 2007 9:22 pm Post Subject:
That particular PowerBreaker plug is specifically designed to de-operate one power fail and not to re-energise when the power comes back.
This is a specific safety feature used where (eg) long extension leads and cutting machines are in use.
Some stay on if the power fails, not this baby.
I wonder if the OP really wants this though. this would mean that if the power fails when you are on holiday then Nemo and his friends wont have a pump operating until you get back from the scuba diving holiday...
__________________ TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Joined: 02 Jun 2005 Posts: 10887 Location: Cumbria, United Kingdom Thanked: 39 times
Posted: Tue Sep 18, 2007 11:50 pm Post Subject:
IIRC the type of RCD circuitry which causes it to drop out on power failure is known as an "Active" whereas the type which stay on are known as "Passive".
Posted: Wed Sep 19, 2007 1:33 pm Post Subject:
I had a plug in RCD (£5 from the orange shed) which would sometimes stay on, sometimes go off. But i think this depends on the type of load with my plug! I appreciate that there are some that are specifically active or passive.
Posted: Wed Sep 19, 2007 5:22 pm Post Subject:
i need to do this because when the power is off for a few hours, the bacteria dies in the pump, (but not in the tank) and if it comes on again the dead bacteria gets pumped into the tank and nemo and his mates die .. thnx for all your help peaple.
Joined: 03 Nov 2006 Posts: 3611 Location: Bedfordshire, United Kingdom Thanked: 22 times
Posted: Fri Sep 21, 2007 11:12 am Post Subject:
The problem of "stale" product in a stalled pump is often dealt with by have a dump valve that opens for a set time whenever the pump is started after a prolonged standstill.
The dump valve diverts the output of the pump to waste so the product in the pump is wasted and some product is used to flush the pump before the valve returns to normal.
In the aquarium pump this would mean only a quantity of water being pumped to waste. A time delay relay operating a three port central heating valve may be all that is needed. Provided the water can be topped up to replace that pumped to waste that might work.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
