DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Mixer Shower Inlet
This topic originated from the How to page called Installing a shower
Click here to return to the page called Installing a shower.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
- J -
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 20, 2007 11:37 pm    Post Subject:
Mixer Shower Inlet
Reply with quote Thanks
I am trying to fit a concealed shower mixer but I am having problems fitting the hot & cold inlet.
The inlets are on a horizontal plane, so I am fitting an elbow with a male thread to go into the female thread of the mixer.
As the elbows need to point down (to recieve the supply pipes) it is not possible to fully tighten these joints, but I understand this is not necassary as long as I have used PTFE on the joints.
On the first try of this I wrapped about 10 wraps of PTFE on the threads and applied a bit of LSX around the end of the joint to fill the slight gap that remained. When I connected the water and turned the joint leaked.
I only left the joint about an hour before connecting, should I have waited longer?
I have now tried joint compound and hemp and currently leaving this overnight to set.
Can anyone confirm if this is the correct way of doing it, and should I just try a little more PTFE / compound?
How long is it expected that a joint like this will last? as it seems it only relies on the sealant than any pressure as in a compression fitting.
Thanks a lot in advance to anyone who can help.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
chrishutt
from St. Pierre and Miquelon
Thanked: 2 times
PostPosted: Fri Sep 21, 2007 5:58 am    Post Subject:
Best to use a straight compression fitting in the inlet connections and then an elbow (preferably male to female) to point the pipe in the appropriate direction.
__________________
Let's face FAQs.
Back to top
 Alert Moderators
- J -
from United Kingdom
Thanked: 0 times
PostPosted: Fri Sep 21, 2007 9:22 am    Post Subject:
Thanks Chrishutt,
Simple unfortunatley doesn't exist in this old house!!!
That was my first idea but due to lots of reasons there is insufficient space to do that.
I have just connected it all up and after 1 hour (touch wood) all seems good.
Jon
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Kitchen Mixer Tap - Dripping from hot inlet 5 260 Mon Aug 24, 2009 11:01 am
Mira Shower Inlet Filter Blocking 4 1200 Sat Jan 27, 2007 7:23 pm
Removing shower inlet plug. 9 320 Thu Apr 17, 2008 5:51 am
Connecting Shower inlet to Hep20 / Plastic 11 2980 Sun Jul 04, 2004 8:35 pm
Shower inlet question 11 2960 Sun Jan 14, 2007 3:08 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
