Joined: 21 Sep 2007 Posts: 4 Location: Berkshire, United Kingdom Thanked: 0 times
Posted: Fri Sep 21, 2007 9:04 am Post Subject:
Wiring 2 lights with 1 switch
We had spot lights put in one of our rooms, now the mrs doesn't like them (there's no pleasing them) and wants the old light put back in. Is it possible to wire both of them in so that they can be operated independently with one switch. There's not enough room to feed another wire for 2 switches without ripping the wall out. (don't mind fitting a pull cord switch to flick between spot lights and the old ceiling light, if need be). Is this possible? Thank you
Joined: 15 Apr 2005 Posts: 12845 Location: Yorkshire, United Kingdom Thanked: 21 times
Posted: Fri Sep 21, 2007 10:26 am Post Subject:
ripping the wall out? You'd have to put a small chase in the wall, not pull it all down! You exaggerate, I think.
Why do you want two sets of lights? It'll be like B&Q's lighting aisle when you've finished.
The easiest solution would be to take the switched live from the wall switch into the COM of a 2-way pullswitch. Then wire one light's live into L1 and the other into L2. This solution will enable you to turn them on and off at the wall, and use the pullswitch to change between them.
Joined: 09 Sep 2007 Posts: 1323 Location: Newcastle upon Tyne, United Kingdom Thanked: 3 times
Posted: Fri Sep 21, 2007 12:05 pm Post Subject:
You might be able to do this without 'ripping out the wall' as you put it. It all depends on how the existing lights are wired up and, in particular, how the switch wire runs. If there's a flat twin and earth running between switch and light, maybe you can use it to pull in a three core and earth.
__________________ Their base is so secret, even the space cats don't know where they are.
Posted: Fri Sep 21, 2007 12:12 pm Post Subject:
Thanks for that Steve.
OK, it was a slight exaggeration, but the reason for keeping spot lights is that they look rather nice and I quite like them, and secondly, taking them out would mean filling the gaps and skimming the ceiling, painting etc etc, too much hard work.
I suppose I could just have the pull cord switch for one set, and wall switch for the other.
The reason for operating from the wall switch was that I have a remote control dimmer on that switch.
Joined: 28 Mar 2004 Posts: 6930 Location: United Kingdom Thanked: 15 times
Posted: Fri Sep 21, 2007 2:14 pm Post Subject:
as space cat suggests if you can replace the T&E switch drop with a 3+E one you can use this to carry a permanent live and two switched lives solving your problem.
Posted: Sun Sep 23, 2007 12:06 pm Post Subject:
Steve, I'm going to put in a pull cord switch to flick between the 2 sets, can you please tell me how the other wires from light1, light2 and wall switch connect with each other?
thank you
Posted: Wed Sep 26, 2007 6:31 pm Post Subject:
You need to connect the switched live from the main switch to the COM terminal.
Connect the L1 and L2 terminals to the lives to the 2 light fittings. The thing to remember with the 2-way switch is that it flip-flops between L1 and L2 on each pull of the switch.
How you do this depends on the way your circuit is wired. If you need drawings to help you understand the lighting circuit there's plenty in the WIKI (top of forum in blue bar).
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
