DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Stepped double glazing sealed units
This topic originated from the How to page called Double glazing
Click here to return to the page called Double glazing.
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
  View previous topic :: View next topic
Author Message
JZMosalski
from United Kingdom
Thanked: 0 times
PostPosted: Sun Sep 23, 2007 8:52 am    Post Subject:
Reply with quote Thanks
I have read about misting problems on double glazing units fitted in wooden frames. Can someone clarify is it the fact that the sealed units come into contact with damp from condensation that causes the misting.
My limited research suggests that the units should be placed on some sort of plastic packing blocks which I assume are designed to allow air to circulate around the units that prevents or at least slows the misting effect.
Also my existing units are bedded in normal putty should a butyl based putty have been used.
In summary can someone explain how the glazed unit can be bedded in putty and at the same time be rested on plastic blocks which prevent the unit form resting on the wooden window frame. Surely by the very fact that putty is used then there cannot be a clear area around the sealed unit which allows air flow. If someone can clarify this situation or better still can point me in the direction of a site which illustrates the process I'd be very grateful.
Regards,
Jan
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
masona
from United Kingdom
Thanked: 7 times
PostPosted: Sun Sep 23, 2007 9:42 am    Post Subject:
Re: Stepped double glazing sealed units
Are you talking about the misting inside the double glazing unit, if so, then the seal has gone so it's cheaper & quicker to renew the unit.
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
The-brickie
from United Kingdom
Thanked: 4 times
PostPosted: Tue Oct 09, 2007 2:50 pm    Post Subject:
I never use an aggressive type of 'sticky' bedding compound, which by its nature sticks to the glass and the wood.
We all know that wood moves, so what happens is that the sealed unit is actually pulled apart by the movement of the wood, sitting in a non drained rebate doesn't help either.
I tend to use double sided foam, aka security foam at least on one side which will allow for the movement and, as the op said, plastic packers under the unit and if possible some drainage at the bottom.
__________________
Not in to DIY, I do it all day long........
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Fitting sealed units into wooden frames. Methods? 11 680 Wed Jul 22, 2009 4:14 pm
Marks inside sealed units 6 600 Mon Nov 27, 2006 10:56 pm
24mm vs 28mm Sealed Units 8 1040 Thu Jan 25, 2007 8:54 am
Double Glazing - Glass replacement/Sealed unit? 5 680 Fri Sep 12, 2008 3:33 pm
Removing sealed unit 2 360 Mon Aug 25, 2008 9:22 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
