ewqiop
Joined: 26 Sep 2007 Posts: 3 Location: Norwich, United Kingdom Thanked: 0 times
Posted: Wed Sep 26, 2007 7:05 am Post Subject: Plumbing |
I have a smell of sewage in my bathrooms which I cannot get rid of. I called out Dyno Rod thinking that I must have a blocked drain but they said the drains were fine. They suggested that I might have a faulty stack pipe valve. Do you think that this could be the problem? The house is only 18 months old so do you think that the builders should put this right? If not can you let me have details of a company I could use who will be able to deal with this problem efficiently and not too expensive? I live in Norwich, Norfolk. |
gas4you
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Wed Sep 26, 2007 7:21 am Post Subject: |
The builders are responsible for nearly everything in the first 2 years of your warranty.
Get them back asap. __________________ Dave
DRL Gas Services |
hi-spec plumbing heating
Joined: 13 Sep 2007 Posts: 1277 Location: Essex, United Kingdom Thanked: 0 times
Posted: Wed Sep 26, 2007 10:02 am Post Subject: |
you don't tell us nothing about your stack pipe so how can we help ?
if it is an internal stack pipe with an aav fitted they can get stuck or if they have been boxed in with no vents they don't work how they should. |
ewqiop
Posted: Wed Sep 26, 2007 11:28 am Post Subject: Plumbing |
I'm a girlie so I don't know what sort of Stack pipe it is. It's a new house and the pipe goes up through the house presumably into the loft. Dyno Rod told me it could have a faulty valve so I'm guessing that's what you mean by AVV. I can't DIY so does anyone know of a good plumber who can repair this for me. Norwich area. |
kevplumb
Joined: 18 May 2004 Posts: 19144 Location: Tennessee, United States of America Thanked: 400 times
gas4you
ewqiop
Posted: Thu Sep 27, 2007 7:52 am Post Subject: Plumbing |
I have asked the builder but it took them 7 months to rectify the last problem I had and I'm not sure I can live with the smell that long. |
