rattray
Joined: 26 Sep 2007 Posts: 1 Location: Cardiff, United Kingdom Thanked: 0 times
Posted: Wed Sep 26, 2007 9:57 am Post Subject: Instaling a Socket from lighting circuit via a small consume |
I have power into my Garage Via my outside lighting circuit. Can i place the wire running into the garage to a Small Consumer unit and run of power via the different fuses to lights and more sockets. |
JohnD
Joined: 15 Nov 2005 Posts: 24037 Location: Hampshire, United Kingdom Thanked: 54 times
Posted: Wed Sep 26, 2007 10:10 am Post Subject: |
no. a lighting circuit wil be fused at 5 or 6 amps, which is sufficient for lighting but not for sockets. |
Cremeegg
Joined: 16 Apr 2007 Posts: 491 Location: United Kingdom Thanked: 0 times
Posted: Wed Sep 26, 2007 10:30 am Post Subject: |
A brave assumption - it should be fused at that level but based on many DIY projects I've seen I wouldnt be surprised at a 13A fuse in the FCU or at least that in the MCB. I'd like to check the CSA of the cable as well. |
Albert
Joined: 17 Feb 2004 Posts: 697 Location: United Kingdom Thanked: 0 times
Posted: Wed Sep 26, 2007 12:21 pm Post Subject: |
Supplying sockets from a light circuit is a very bad and unsafe practice.
As mentioned; each type of load (light and power) have different characteristics and different cable size, MCB/Fuse size and a different disconnection time requirement. __________________ I'm not in a mental institute... just a house for the insane |
