DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Cloakroom Sink Waste
This topic originated from the How to page called Drainage Systems
Click here to return to the page called Drainage Systems.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
bcday
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 12:45 pm    Post Subject:
Reply with quote Thanks
I have plumbed a new sink into my downstairs toilet and I was going to use the old waste pipes that are already there, however, I needed to slightly adjust the angle. I have bought a push fit waste bend and the extra 32mm waste pipe I need, but the old waster pipe is about 2 mm bigger, what do I need to get to avoid me having to change all the waste pipes (it would mean a lot of work doing that!)
cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
hi-spec plumbing heating
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 12:52 pm    Post Subject:
sounds like you have got 32mm compression waste that is slightly bigger than pushfit waste
Back to top
 Alert Moderators
bcday
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 2:08 pm    Post Subject:
So what does that mean I need to get, I don't want to replace the old waste that is in place, are there other push fit wastes that I can get??
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 2:17 pm    Post Subject:
Back to top
 Alert Moderators
bcday
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 2:52 pm    Post Subject:
what type of fittings was on it before.
http://www.screwfix.com/search.do?_dyncharset=UTF-8&fh_search=33323
or
http://www.screwfix.com/search.do;jsessionid=HMQH4ZJ2GL5UACSTHZOCFFY?_dyncharset=UTF-8&fh_search=35203
The waste pipe went directly into the trap, there was no fitting, however now the trap is in a different position to my previous sink as it is a vanity unit and I therefore need a fitting to change the angle and connect the trap to the waste pipe?? I hope this makes sense
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 2:58 pm    Post Subject:
yes but was the trap a push fit, or compression with a nut
Back to top
 Alert Moderators
bcday
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 3:00 pm    Post Subject:
Apologies, it was compression with a nut, I have bought a new trap and additional waste pipe (which is thinner) plus the angled connector, which fits the new waste pipe but it too small for the old
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 3:05 pm    Post Subject:
right getting there.
if your new trap is compression same as old you must stick with that type fitting & pipe.
pushfit pipe/fittings don't go with compression.
so you need to take the pushfit pipe & fitting back and change for compression pipe/fitting
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Cloakroom sink waste routing. 3 1400 Thu Jan 10, 2008 5:05 pm
Isolating Sink In Cloakroom 2 180 Mon May 05, 2008 11:24 am
Cloakroom sink drainage 4 1540 Wed Mar 08, 2006 10:46 am
Slow emptying cloakroom sink 2 360 Sun Oct 03, 2004 1:49 pm
Victorian House 5 Bedrooms 2 Bathrooms Cloakroom Toilet 5 360 Mon Oct 15, 2007 6:12 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
