DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
2 way light socket
This topic originated from the How to page called Replacing a one way light switch with a two way light switch
Click here to return to the page called Replacing a one way light switch with a two way light switch.
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK
  View previous topic :: View next topic
Author Message
geeno67
from Canada
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 2:14 pm    Post Subject:
2 way light socket
Reply with quote Thanks
just replacing a light switch from a dimmer switch. problem is the remaining light switch has just 2 connectors the new light switch has 3(ground) all wires are hooked up. I only have 2 wires remaining should i unhook one of the grounds from the box and move it to the light switch? icon_biggrin.gif
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
bernardgreen
from United Kingdom
Thanked: 22 times
PostPosted: Thu Sep 27, 2007 2:21 pm    Post Subject:
icon_biggrin.gif icon_biggrin.gif Only if you want to make a flash bang pop icon_biggrin.gif icon_biggrin.gif
Back to top
 Alert Moderators
mikeyd
from United Kingdom
Thanked: 3 times
PostPosted: Thu Sep 27, 2007 2:26 pm    Post Subject:
Are you completely sure the extra terminal is a ground terminal? If it is you should not move one of the grounds to this terminal, you would put a new link between the existing 2 grounds in the box and the ground terminal on the faceplate. (Is it a metal switch?)
If you are not sure it is a ground terminal then we may see the flash from here if you connect to it.
PS Your post will probably be moved soon into the non-uk section.
Back to top
 Alert Moderators
Taylortwocities
from United Kingdom
Thanked: 63 times
PostPosted: Thu Sep 27, 2007 2:27 pm    Post Subject:
Didnt know there was electricity in Canada, blimey.
Suggest you post on Electrics outside of UK. We've got enough troubles of our own.
__________________
TTC
When you get to the end of your rope, tie a knot and hang on. - F.D.R.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Electrics Outside of the UK All times are GMT
Page 1 of 1
Jump to:
Plug socket on light circuit? 13 1520 Tue Sep 06, 2005 1:17 pm
Adding power socket to light switch 5 1440 Fri Feb 03, 2006 8:27 pm
Austrian socket - what goes where? 4 880 Sat May 06, 2006 10:19 am
Good Socket/Good Bulb But Bulb Works Intermittently 3 560 Wed May 31, 2006 4:44 pm
wiring a socket to a lighting circuit 3 1100 Thu Jul 05, 2007 1:00 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
