DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
1 gang dimmer - low bulb output
This topic originated from the How to page called Replacing a one-way light switch with a dimmer switch
Click here to return to the page called Replacing a one-way light switch with a dimmer switch.
  View previous topic :: View next topic
Author Message
ianmcdlt
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 3:46 pm    Post Subject:
Reply with quote Thanks
I changed a light switch to dimmer. Only red and black cable. Straight swap. Black in L1, red to ~.
When I turn the power on the dimmer intermittently works and when it does only generates a low glow to the bulb when dimmer is turned to maximum. (single bulb).
Could anyone shed light on my problem?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
plugwash
from United Kingdom
Thanked: 16 times
PostPosted: Thu Sep 27, 2007 3:51 pm    Post Subject:
is it an ordinary filament bulb running directly off the mains? is it between the minimum and maxium power ratings of the dimmer?
if the answer to both those questions is yes then it is almost certainly a faulty dimmer.
Back to top
 Alert Moderators
ianmcdlt
from United Kingdom
Thanked: 0 times
PostPosted: Thu Sep 27, 2007 4:07 pm    Post Subject:
Thanks Plugwash for reply,
Ordinary filament bulb = 60W 240 volt.
Dimmer = 1 Gang 2 way 250 Watt Dimmer
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
1 gang - 3 output switch 2 140 Thu Feb 12, 2009 5:49 pm
Dimmer switch with "un-dimmed' output? 5 180 Thu Aug 20, 2009 7:16 pm
Weak light output 3 360 Mon Feb 12, 2007 5:41 pm
Noisy electical output from new TV 15 540 Fri Dec 29, 2006 5:47 pm
Output wiring from SELV transformer - T+E OK? 10 1660 Tue Mar 14, 2006 10:22 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
