Baxi combi boiler 80e hot water light stays on
27 Sep 2007
Hi
When I turn on a hot tap the hot water light on my baxi combi boiler 80e comes on as you'd expect.
When I turn the tap off again the light stays on. This then prevents the central heating from comming on.
If I switch the boiler off and on again, the hot water light is reset and the cetral heating will work; until I turn a hot tap on again!
Any suggestions please. My wife doesn't like the cold. :(
Microswitch sticking on or Flow switch might be sticking open.
It was the microswitch that detects the water flow. It was sticking in the closed position.
A new microswitch from Maplin cost me £1.99
Saved me a fortune. Thanks for your advice. :D
