Hi
My new house has had some very dodgy work done to the heating system before i bought it. Basically, what i found when i arrived was a 3 port valve (i am assuming it is 3 port cos it has 3 pipes on it) with no actuator motor attached meaning i have to manually select hot water/heating and some magical wiring whereby the cylinder stat controls the boiler. The room stat downstairs is connected to the junction box but does nothing.
I am pretty sure i can sort out the electrics but i am hopeless at plumbing (fear of drowning!) and was wondering if i could just add in a new actuator motor which would be a hell of a lot easier than replacing the valve. Can anyone tell me what i need to buy to simply plug in a new motor or would any do?
The only details I can see on the valve are that is was made by satchwell and has an id of DT1702. I have searched the web but cannot find out any info about what i need. If not, how easy is it to replace the whole valve and what needs to be done to safeguard the house from serious flood damage?
Many thanks in advance.
Mark
Mark
