Joined: 28 Sep 2007 Posts: 6 Location: Lincolnshire, United Kingdom Thanked: 0 times
Posted: Fri Sep 28, 2007 6:46 pm Post Subject:
Pilot light going out
Hi guys, I have an old spacesaver 38 and since the weather has turn cold I have had to put the CH on instead of just water, and everytime I try the pilot light goes out after about 10mins.
With just the hot water selected it will stay lit all the time, any suggestions.
BTW Its a new thermocouple
Joined: 23 Feb 2007 Posts: 14312 Location: Norwich, United Kingdom Thanked: 41 times
Posted: Fri Sep 28, 2007 6:48 pm Post Subject:
Is it an old gravity primary system?
If so check the ch pump hasn't stuck making the boiler overheat. I think the overheat may be linked to the thermocouple on this one, but can't remember for certain.
Posted: Fri Sep 28, 2007 7:11 pm Post Subject:
No its a fully pumped system so I am led to believe, and I can hear the pump in the bedroom under the floor boards and the rads are getting warm, its currently been 15mins without going out (thats a first!)
Would air locking do this and basically the pilot is the safety system to stop overheat as I have had air in one of the rads nearest the tank
Posted: Fri Sep 28, 2007 7:19 pm Post Subject:
Looks like I found the problem, when I switched from hot water to CH I can hear like running water down the inside of the pipe suggesting air in the system, I have ran around the rads and no air from them though.
Joined: 09 Sep 2007 Posts: 1323 Location: Newcastle upon Tyne, United Kingdom Thanked: 3 times
Posted: Fri Sep 28, 2007 7:39 pm Post Subject:
It can be a pig of a job getting the air out of radiator pipework. Sometimes you need full pump pressure to blow an airlock out of an inverted loop of pipe. On the other hand it is possible for the pump to suck air IN through bleed valves when you open them. It all depends on where the pump is in the circuit.
I inherited a badly laid out system with many inverted loops and I find the following method works:
1) Turn off all the radiators except the one nearest the boiler.
2) Run the pump and listen for air.
3) When all seems quiet, STOP THE PUMP and bleed that radiator.
4) Turn that one off and open the next one.
Repeat steps 2, 3 and 4. You may have to go back to the first radiator and repeat the whole cycle. With pumped hot water I treat the cylinder coil as a radiator.
__________________ Their base is so secret, even the space cats don't know where they are.
Joined: 12 May 2004 Posts: 7929 Location: United Kingdom Thanked: 59 times
Posted: Fri Sep 28, 2007 9:41 pm Post Subject:
There is nothing on a space saver that would affect CHmore thanHW..Other than the length of time the ain burne is on to give aount of heat.... your pilot is partially blocked and needs cleaning.
Posted: Sun Sep 30, 2007 4:09 pm Post Subject:
It is a partially blocked pilot (being pulled away from t/couple) that is going out simply because on heating the main burner is on longer than it is on for just HW,,, Which is why it stayed on when you turned the stat down( boiler cutting on and off sooner)...
There is no over heat stat or anything connected to the pilot on an old 38 spaceaver that air in sytem or boiler overheating would affect..
At worst it may be a slight leak on heat exchanger that is opening up when it has been on for a while and driping onto pilot
Posted: Mon Oct 01, 2007 6:21 pm Post Subject:
Thank you very much, it was the pilot light partial blocked after all, even though the flame was blue and looked OK, I havent had a problem since I cleaned it.
Joined: 26 Jan 2009 Posts: 2 Location: Lancashire, United Kingdom Thanked: 0 times
Posted: Mon Jan 26, 2009 1:39 pm Post Subject:
hi
ive just found my baxi solo 2 r.s central heating boiler gas light keep going out & when i relight it it gos out in about ten min, can you tell me the prolem
thank you
roy butterworth
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
