DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
No earth connection in light socket??
This topic originated from the How to page called Connecting a flex to a bulbholder
Click here to return to the page called Connecting a flex to a bulbholder.
  View previous topic :: View next topic
Author Message
mick0658
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 29, 2007 6:41 pm    Post Subject:
Reply with quote Thanks
I have just moved a 2 way light switch. The new switch has Com, L1 and L2 but no Earth. The original back box was a metal flush box with an earth connection but the new one is a single dry liner box (it is in plasterboard) but it doesn\\\'t have an earth connection. What do I do with the earth wire?
I\\\'m using 1mm T&E plus extra live wire
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
mick0658
from United Kingdom
Thanked: 0 times
PostPosted: Sat Sep 29, 2007 6:44 pm    Post Subject:
Just read through the forums - and found the answer! Doh...that will teach me. I'd already put the earth wire in a choc block, sleeved correctly and wrapped away neatly (just in case)
Apols for wasting the forums time
Back to top
 Alert Moderators
Lectrician
from United Kingdom
Thanked: 20 times
PostPosted: Sat Sep 29, 2007 6:51 pm    Post Subject:
Just stick it in a terminal block - Do not tape it up! Yuk!
Also, when you say "an extra wire", I hope this is double insulated?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Bathroom wall light connection - earth loop problem 4 540 Sun Nov 11, 2007 3:04 pm
Light fitting has no Earth connection? 7 6920 Sat Nov 20, 2004 5:53 pm
Earth Connection in Light Switch? 3 160 Thu Oct 01, 2009 8:14 am
Service Provider Earth Connection 8 660 Fri Dec 30, 2005 1:33 pm
10mm earth connection to incoming water pipe 4 580 Tue Nov 27, 2007 5:43 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
