azizrasul
Joined: 10 Sep 2005 Posts: 10 Location: Staffordshire, United Kingdom
Posted: Sat Sep 29, 2007 9:43 pm |
I have a 1.6 Vauxhall Astra automatic in which I had valves cleaned a month ago as the car would conk out before it slowed down to a halt. Now I've got the same problem again and it's going to cost over £250 to have them replaced, which I can ill afford right now.
Can someone tell me where these valves are located and how they can they be cleaned? |
Stivino
Joined: 11 Oct 2006 Posts: 2111 Location: Midlothian, United Kingdom Thanked: 128 times
Posted: Sat Sep 29, 2007 10:05 pm |
Could you give a bit more information on what valves you mean? |
azizrasul
Posted: Wed Oct 10, 2007 8:51 am |
Apparently it's called the EGR valve if that means anything? |
InTheBeginning2007
Joined: 20 Aug 2007 Posts: 90 Location: Bedfordshire, United Kingdom
Posted: Wed Oct 17, 2007 2:18 pm |
That doesnt sound right?
What year is it?
I know on other cars, a failing MAF sensor causes these symptoms. |
davieboy
Joined: 20 Dec 2004 Posts: 237 Location: Fife, United Kingdom Thanked: 12 times
Posted: Thu Oct 18, 2007 8:10 pm |
egr valve sounds very possible for this symptom, on an astra. seems a tad overpriced considering the trade price on the valve from a main dealer is around 36 quid and takes only 10 mins to fit. |
kev25v6
Joined: 17 Jan 2006 Posts: 162 Location: Derbyshire, United Kingdom Thanked: 2 times
Posted: Sat Oct 20, 2007 4:09 pm |
Sounds more like the icv valve is sticking. The idle speed control valve is what stops your engine from stalling when coming to a stop. Find it and clean it out with carb cleaner, it would most likely sort out your problems. |
